Has it got the plastic thingy on the back? If so you don't need that, should be able to remove and then stick the glass with a decent expoxy glue or double side stickers. Should be OK.BeemerMad wrote:I have bought the whole replacement now. Is it easy to do the whole thing?Lillywhite wrote:The black backing is the heated pad. All you need is a replacement piece of glass, a tenner or so off eBay. Wingmirrorman supplied mine.
How do replace a wing mirro glass
- Lillywhite
Re: How do replace a wing mirro glass
2015 Mazda MX-5 Roadster Coupe 25th Anniversary Limited Edition (#0195), personal number plate
2005 Series 1 116i Sport, Titan silver, personal number plate
- BeemerMad
Hi yes it comes with the black plastic clip. If i use sticky pads and stick it in, will it not affect the mirror heating up?
- Lillywhite
Mine is fixed with sticky pads that were supplied with the replacement glass and it works fine. Many on this forum use expoxy glue but make sure that it's better than the c**p glue that was orginally used by BMW OEM!BeemerMad wrote: If i use sticky pads and stick it in, will it not affect the mirror heating up?
- BeemerMad
Thats great thanks. Thankyou all for your replies.Lillywhite wrote:Mine is fixed with sticky pads that were supplied with the replacement glass and it works fine. Many on this forum use expoxy glue but make sure that it's better than the c**p glue that was orginally used by BMW OEM!BeemerMad wrote: If i use sticky pads and stick it in, will it not affect the mirror heating up?
Its quite difficult driving on a motorway with no drivers side mirror!!!
Does your mirror still defrost after using sticky pads?
- Lillywhite
- BeemerMad
Would UHU glue be suffice?
- BeemerMad
- Lillywhite
Not something I would use, some have used Araldite although I didn't want to trust glue again because the reason many mirrors fall out is because the glue gets brittle.BeemerMad wrote:Would UHU glue be suffice?
- BeemerMad
Hmmm, could you recommend some double sided sticky pads then please. Thickness more than anything cheersLillywhite wrote:Not something I would use, some have used Araldite although I didn't want to trust glue again because the reason many mirrors fall out is because the glue gets brittle.BeemerMad wrote:Would UHU glue be suffice?
- BeemerMad
Got some now about 2mm thick. Thankyou Lillywhite for your help greatly appreciated
- TiffAnsell
My passenger side glass fell off on the way from kent to Poole... Used silicone and it seems fine now, heats up well too. Only thing is it has abviously come off before as the passenger side isn't the same as the drivers which now I've noticed, really bugs me
3.0 2006 build 2007 reg coupe. "burnished" gold rep csl rims on goodyears
