E89 Comprehensive problem list
- B21
2011 MY Atacama Yellow 35is 50,000 miles August 2021 purchase from a small dealer.
‘Recently serviced, new MOT’
On purchase dozens of fault codes seen, all cleared with Protool. Then no codes showing.
September 2021 number 2 ignition coil fail, discover one Index 12 injector fitted to a bank of Index 9 injectors in contravention of BMW service procedures. Temporary number 2 coil replacement as get you home, then replace all coils with new NGK coils (after failed attempt to use Hella version, recently refunded by Autodoc) Approx cost of parts £150.
October 2021 discover both front adaptive shocks leaking, lack of apparent rebound damping and soft springs on rears, replaced with Ohlins R+T Approx cost of parts £2,300
November 2021 replace all injectors with fresh set of Index 12 injectors. Approx cost of parts £1500
- Zed Baron
1. 23i
2. 2009 / 09
3. Alpine white
4. Black Kansas extended
5. Purchased privately 2014
6, Full BMWSH currently at 35k miles
Regular oil/brake fluid, filter changes. Battery replaced, roof relays etc. Booked in for gearbox service/coolant flush.
5. Issues experienced, notes & status e.g.
5a. Plastic hinge on roof boot tray broken
5b. Repaired it myself after finding solution on forum, cost to repair £0.90
6a. O/s/r spring broken
6b. BMW wanted £190, bought 4x springs for £80 off car that had done 400 miles, got it fitted for £30
6a. N/s/r spring broken
6b. Fitted for £30 (from the set I bought)
7a. Roof wouldn't fold from key fob
7b. B21 Kindly reprogrammed using Carly, found other fault codes also, cleared them, monitored regularly and none since (suspect these were all battery related).
2. 2009 / 09
3. Alpine white
I have a 2010 E89 with the LA spoke 290 wheels. when the runflats needed replacing i put on non runflat tyres. ride is much smoother and no cracks after 100km.
- B21
Water pump failed with motor overheat and DMW failure to respond to speed requests..
2011 35is 60k miles
Bought the uprated Pierburg all alloy pump and Mahle thermostat to fit at same time..
2011 35is 60k miles
- 2022-08-17 14.24.20.jpg (177.92 KiB) Viewed 8638 times
- 2022-08-17 14.24.27.jpg (221.42 KiB) Viewed 8638 times
- TOMGREEN413
White e89 Red leather 18i M spec 2014
Owned 3 years
Mileage was 38k now 54k
Bought from independent garage
Issues
Cracked plastic rocker cover............fixed 2 years ago with a poxy high temp resin....no leaks since
After 3 years of daily use and regular servicing its been perfect......not bad for an 8 year old car.
Owned 3 years
Issues
White e89 Red leather interior (But that's the wife's and don't I know it :/ )
Montego Blue Coupe manual si sport (Faster than the above....much faster
- B21
I think it’s epoxy?TOMGREEN413 wrote: ↑Wed Dec 07, 2022 9:51 am White e89 Red leather 18i M spec 2014
Owned 3 years
Issues
Good to know that’s a viable solution…
Most cars tend to be more reliable when used regularly
- TOMGREEN413
poxy stuff.....gets everywhere!!
- Christopher72
2011 E89 sDrive35i - Deep Sea Blue, Beige Kansas Leather - purchased Fall 2022, USA LHD, no warranty. 88k miles
Oct 2022 - Cracked rear wheel - resolved
-- replaced cracked 19" Style 296 V Spoke Wheel (36116785257)
-- replaced 19" Perelli Run flat with Goodyear Eagle F1 asymmetric 3
Jan 2023 - Exhaust rattle - resolved
-- Inspected, used washers to fill the exhaust flap gap, fixed rattle
March 2023 - Oil in spark plugs - resolved
-- replaced Valve Cover Gasket (11127565286)
-- replaced Blow-By Vent Hose (11157553949)
April 2023 - Cylinder 6 misfiring resolved
-- replaced Injector index-9 (remanufactured), teflon seal, decoupling ring on cylinder 6
April/May 2023 - A68B: Microswitch, roof shell 2 closed, left - Still Erroring Occasionally
-- replaced boot microswitches (954377228585) & (54377228586)
-- Haven't yet found the problem on left side of shell 2 hydraulic arm...
May 2023 - Damaged 3rd brake light cover and trunk seal resolved
-- Replaced taillight cover (51137252844)
-- Replaced seal from used Ebay donor trim (54377224676)
June 2023 - Slightly Cracked front wheel - resolved
-- Welded, Refinished, and trued 19" Style 296 V Spoke Wheel (36116785256)
June 2023 - EGS [DKG_90] | 5A53: Transmission overheating: phase Red - Delaying until rain
-- Planning full DCT service with OEMish parts. (fluid, filters, pan with gasket and drain plugs)
August 2023 - Coolant Pump Failure @90.9k miles resolved
-- Replaced Coolant Pump with full metal Pierburg Coolant Pump
-- Replaced thermostat with Mahle OEM part - preventative maintenance
-- Replaced radiator with full metal CSF performance radiator - preventative maintenance
-- Replaced full set of coolant hoses to VTT silicone hoses - preventative maintenance
Sept 2023 - Cracked sway bar bushings - resolved
-- Replaced bushes with Powerflex (PFF5-4602-26.5)
Last edited by Christopher72 on Fri Sep 08, 2023 7:31 pm, edited 5 times in total.
Christopher
2011 E89 Sdrive35i - Deep Sea Blue, Beige Kansas Leather
'fits in progress - PDC, Cameras, Comfort Access, Respray/Correction - all queued for poor weather.
(9) E46 convertibles; (1) E39 540i; (2) E36 Z3 roadsters; (1) Pre-prod E36 Z3- all gone
Yesterday picked up the successor to my Toledoblue E85 3.0i S, its a lovely looking E89 35iS in Melbourne Red, pic below:
https://imgur.com/a/YHzJxko
However, on my second drive the car displayed following:
1. E89 35iS DCT
2. 2010
3. Melbourne Red
4. Kansas Black
5a. Car seemed to have serious trouble accelerating, almost shutting of at low speeds. Quite some vibration and strange noises in the car which seemed to come from the drivetrain. My own thoughts immediately were either one or multiple cylinders failing / misfiring, a DCT issue, a big vacuum leak, or something fuel related (injectors or pumps)
5b. Current status - Unresolved
5c. Car has a 6 month warranty for drivetrain, transmission, and roof. Didn't contact them yet, wanted to check here first.
5d. Mileage = 118k kms (73k miles)
5d. Car is stock, no ECU maps on it AFAIK
5d. Used my OBD code reader on the car and the DME department had two fault codes stored:
- 2DED > 'Power management, close d-circuit current violation'
- 29D0 > 'Combustion misfires, cylinder 4'
Luckily, the car was delivered to me with a large service done just last week, during which also the spark plugs were changed. So I'm thinking it may be ignition related, maybe a bad coil? Look forward to reading your replies.
1. E89 35iS DCT
2. 2010
3. Melbourne Red
4. Kansas Black
Current
2010 E89 Z4 35iS Melbourne Red (weekend)
Former
2004 E85 Z4 3.0i SMG Toledoblau (weekend)
2001 E46 Coupe 325Ci Orientalblau (project car)
2017 Mazda MX-5 ND 1.5 GT-M Soul Red Crystal (weekend)
2003 Peugeot 206 GTI
1998 Peugeot 106 Sport
Former
Online
Talking to a gentleman at Lincoln BMW, admiring his G29.
Interestingly he had E89 20 for a few months, said he got rid of it due roof rattles.
Treated himself to fully loaded 140i.
Got to admit it has grown on me a little.
1. E89 Model 35iS
2. Year 2010
3. Colour exterior Melbourne Red
4. Colour interior Ivory White
5a. Issue description - Boot soft close erratic. Failure imminent
5b. Current status - Resolved
5c. Warranty Claim? - No. Work done by local BMW independent
5d. Comments? - Partial rewire. One hour's labour. £75
2. Year 2010
Vidi, vici, veni
1. E89 Model 35iS
2. Year 2010
5a. Issue description - Rattle from boot when roof up. Quiet when roof down
5d. Comments? - Replace load cover brackets (hinges) & test drive. £68.20 ex VAT the pair. 1/2 hour labour £37.50.
2. Year 2010
Vidi, vici, veni
