Quoted £140 + Vat for a new key....Ouch
- SDS
I had seen a top end figure of £100 bounded about on here before, but was not expecting £140.
I have the master plastic key and just one immobiliser, so I need another.
Is there no other way around this?
I realsie this has been discussed before quite a bit, but I can't quite grasp the outcome of the eBay key talk!
Cheers.
Cheers.
Re: Quoted £140 + Vat for a new key....Ouch
Try other BMW agents, Some will be cheaper. I paid £133.33 inc Vat last July. My previous car was an Audi, a replacement key cost £180!!
- SDS
£180! Wow. That makes me feel slightly better.Max wrote:Try other BMW agents, Some will be cheaper. I paid £133.33 inc Vat last July. My previous car was an Audi, a replacement key cost £180!!
I'll do a ring-around
- cj10jeeper
Ebay key
You may be able to get a blank and get it cut to physically fit and open the lock
You can easily programme any Zed key to set and disarm your alarm (ebay, old scrap key,e tc.)
You CANNOT replicate the transponder in the key that pairs to the engine to allow it to start
In your case as you need a new key and not putting internals into a new case it's no use.
Hope that helps
Hope that helps
- SDS
Ahh okay. Understood!cj10jeeper wrote:Ebay key
Hope that helps
Seeing as I have the plastic key to start the engine, I could just get one cut and programmed to open the doors/ set the alarm...
- cj10jeeper
Well you would need a blank blade then find someone who cuts this type, to cut and then insert that into a scrap Z4 key.
Frankly I can't see the point, just shop around, bite the bullet and buy a key. You'll need it when you sell it and have all the convenience of 2 propoer keys while owning and in time I bet the plastic key will break off in the ignition
- SDS
Fair point.
Just been quoted £130 inc vat, so it's on it's way down I guess...
- Taz
and on the subject of keys, make sure you use both keys periodically to charge the batteries
have you checked with Joe @ Sopers of Lincoln? he knows about the forum and might be able to do a better deal for you.SDS wrote:Fair point.
- RichardG
Tempting fate here, but I have nearly always used the same key since purchasing my Z and on the odd occaision I have used the 2nd key (usually after reading something like this) it has always worked. Never quite got my heads round the fact the ignition barrell must be live to allow charging.Taz x wrote:and on the subject of keys, make sure you use both keys periodically to charge the batteries
04 2.5 SE, Alpine iDA X-305, Eibach's, M Tri-Colour MFSW, CF Roundells, LeatherZ Armrest, De-Gingered, 19" VMR V710's, Aero Skirts, Fr & R M Bumpers, Quad Exhaust and NO Stubby
- Taz
RichardG wrote: Never quite got my heads round the fact the ignition barrell must be live to allow charging.
ditto, but I have read it several times on here, I have also pondered over how the postive and negative are connected
- cj10jeeper
Surely it will be done by induction charging. Similar to the toothbrushes that fit on a stand with no wired connection?Taz x wrote:RichardG wrote: Never quite got my heads round the fact the ignition barrell must be live to allow charging.
- RichardG
That might be the case but it would still require a power source (I know it's the ignition so there is one there) and then some kind of generator (My only real dealings with induction are for heat generation, warming up bearings or more lately getting layers of Polyethelene via an aluminium layer to high enough temperatures to allow fusion with other layers)cj10jeeper wrote:Surely it will be done by induction charging. Similar to the toothbrushes that fit on a stand with no wired connection?Taz x wrote:ditto, but I have read it several times on here, I have also pondered over how the postive and negative are connectedRichardG wrote: Never quite got my head round the fact the ignition barrell must be live to allow charging.
Anyone got a wiring diagram or is an ignition barrel £500 or a £1000 for the 'M'
- SDS
Thanks, I'll give them a go.navid.v wrote:have you checked with Joe @ Sopers of Lincoln? he knows about the forum and might be able to do a better deal for you.
- SDS
Ah, just thought thought; will they not need to see the car at some point? I'm in Essex...
