I think I have the latest software being 4-1/00.
The intravee manual suggests that 4-1/40 or above is required for enhanced options like scrolling through a list of Albums rather than the next or increments of 10.
Anyone?
TIA
Navigation s/w version?
- jimbo1958
Z4 e85 3.0 - GONE
Z4 e89 35i - GONE
Jaguar F Type V6s Roadster
Abarth 695 Rivale
Z4 e89 35i - GONE
Abarth 695 Rivale
- pvr
Re: Navigation s/w version?
Yes, so you have version 100 then which is great (ie. 100 is shown as 00)
Set your Intravee to 40 or above and you will have the advanced options available
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- jimbo1958
Cheers......something else on tomorrows todo list.pvr wrote:Yes, so you have version 100 then which is great (ie. 100 is shown as 00)
Z4 e85 3.0 - GONE
Z4 e89 35i - GONE
Abarth 695 Rivale
Z4 e89 35i - GONE
Abarth 695 Rivale
- pvr
You mean in addition to going to work?
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- jimbo1958
Not back to work until Weds so plenty of play time.pvr wrote:You mean in addition to going to work?
Z4 e85 3.0 - GONE
Z4 e89 35i - GONE
Abarth 695 Rivale
Z4 e89 35i - GONE
Abarth 695 Rivale
- road warrior
If you ever think I'm off my rocker.. Just put me back in it and walk away... It's the kindest thing
My wife says I never listen - or something like that.
gone but not forgotton -Mean Steve - made a sound like a bear with his nuts in a trap.
- PerryGunn
This applies to the Mk IV navigation system - so any E85/86 with nav.
To find the current version go into the settings menu and you will see SW x-y/zz In the upper right hand corner and it should say something like SW 4-1/00
SW x-y/zz breaks down as
x should be 4 indicating that it's a MKIV nav
y shouild be 1 indicating that it's the full colour 'high' nav system
zz is your current firmware version
00 = v31 or v32 (latest official versions, released in 2008, BMW didn't update the number between releases)
91 = v29.1 or v30 (BMW didn't update the number between releases)
80 = v28
71 = v27.1
70 = v27
plus you'll find others that tend to be 0(something), these are usually a v32 firmware that has been modified - when I create custom ISOs I tend to modify the internal version number of the firmware to 1002 so it displays under settings as SW 4-1/02
NB you can only 'update' with a firmware version that's different to the one that's already installed so, if you need to install a modified version of the latest firmware that hasn't had its internal version number changed, you first need to install an old firmware version i.e. downgrade first, then repeat the process with the modified disc to upgrade
Alpina Roadster S #320
* Quaife ATB LSD * StrongStrut Braces * Turner RTAB Limiters * Gap-Tech RCH+ *
* Intravee & KCA-420i * Mini 0806 * Cheetah C550 * Stubby *
- road warrior
thanks.. i will go check |!
