How to retrofit M Steering Wheel with Multi Function Control
- MrPT
Re: How to retrofit M Steering Wheel with Multi Function Con
Finally got round to retrofitting the MFSW controls I bought from Mark-Z4. Thanks to Mark and also sideshowbob for the excellent instructions.
I did the cruise control retrofit at the same time - the MFSW job was pretty simple in comparison, although I did have a false start because my 2006 2.5si needed a retrofit cable, which I hadn't initially expected (it was £19.90 inc delivery and VAT from Sopers). The only issue I had was trying to undo the torx screw inside the instrument cluster - was totally stumped by this since a torx screwdriver is too long, but luckily I was able to disassemble a torx multi-tool I have and that did the trick:
The other tricky bit was splicing in the cruise control and MFSW at the same time. Got there in the end, with the help of several cups of strong coffee:
Love the controls - definitely worth it as I am always fiddling with my knob (wahey!).
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- TonyP
Many thanks to the OP for the very concise instructions, I did print off the BMW 12 page document but found I only referred to this thread for fitment.
Anyway, I had a free afternoon today so decided to fit my newly acquired ///M MFSW today, I used the official BMW retrofit lead as of course my car needed it
I dislike scotchlocks & wanted to make proper solder connections, at the lightswitch end I popped the permanent connectors out of the blue socket (pins 21 & 27 - very easy to do), I then carefully bared approx 8mm of the original wires insulation with a Stanley blade & twisted the ends of the retrofit wires around the newly stripped insulation before soldering.
By undoing the connectors out of the blue socket this enabled me to slide on some heatsink sleeving covering the soldered joint and making a decent strain free connection too - an added bonus of no bulky scotchlocks to try & tuck away as well, if you look closely you can see the other connection is already made.
I did one wire at a time so that I couldn't accidentally reverse them when refitting into the blue socket.
below is a photo just before putting a heatgun on to shrink down the sleeving - note the old rag to protect the inside of the dash against any damage from the heatgun.
Total time to swap old SW to new MFSW one was 2.5 hours (excluding the 30 min wait after disconnecting the battery), but I wasn't rushing it.
One unexpected feature is that the buttons light up with the dash
- RJS-Z4
Nice work.. not jealous, at alll.
Titanium Silver E85 Mods Done - 224's, Stubby, Amarone //M seats, ZHP, Retrofitted Wind Deflector, Aux In
- cj10jeeper
Always nice to see a job being done properly with solder and shrink wrap
Hope you enjoy the results
- JazzFM28
I've recently retro fitted a MFSW on a car made in Dec 03, and it does not work, therefore I need to explore the possibility of fitting the retro fit cable as described. Therefore it's not always correct to say that a post Sept 03 car has the wiring already installed.
2003 E85, Black, Full Leather, Sat Nav, 10 Speaker, Bavsound Speakers, Strut braces, plus much more
- bradz
MrGringo wrote:the cost of the cable has risen from £5 to £17. £17 for what is essentially two wires seems mightily expensive. If you can locate the scotch lock connectors elsewhere, you could order two bushing contacts (part 1) from BMW and use those, only thing you'd need to remember is which is which as they'd both be black.
It's part number 61130006663 and only £0.98 for 75cm cables (which you can trim to the size you need). (item 1 on the bmwfans link)
So £2 vs £17.
There we are, hope some of you benefit from this!
Just ordered this today from my local stealers in MK and they were £6.70 (inc vat) for 2x repair cables!
I wasn't expecting to need them on a 2006 coupe!
Adam
Z4M Coupe, E92 M3, E46 M3 Track car
- bradz
Just a Quick note to say thank you for the guide! Spot on!
Easy to follow even with using a different cable!
Adam
Adam
Just curious, i have a 2007 coupe 3.0 with a "M" on steering wheel. I dont think its the top model, looks like this http://i.ebayimg.com/00/s/MTA2NlgxNjAw/ ... z/$_57.JPG
Now the retro fit kit from bmw seems to be for standard wheel
Ive found plastic covers for the M but not the switches, could some one advise which parts i would need
thanks
Carl
thanks
Carl
- hopz121
Just attempted this but the airbag doesn't seem to be fitting flush has anyone else had this probelm?
It's clip in but it's sticll sticking out a fair amount and doesn't seem to want to go any further
Any ideas?
Ash
Any ideas?
Ash
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
- Panta Rhei
Re: How to retrofit M Steering Wheel with Multi Function Control
Yesterday, I spent 1 hour picking my screwdriver throug the holes with no effect. Then my dad came and lighten up the hole so he could see spring left and right arm. With help of my dad and this knowledge, I removed my air bag in 15 seconds. Now I am sure I can remove this problematic air bag every time with no much effort. I used flat-head screwdriver.
Fitted mine today using this guide. Fantastic how-to. Cheers sideshowbob. Mine is a 09/03 and I needed the cable but got it from Sopers for £11. Only two issues - 1. Airbag light came on when I was finished and I had to talk nicely to a mate to reset it for me, and 2. The airbag fits "ok" but it seems to sit a little proud of the wheel and as such rests on the bottom spoke and if I press on the top of the airbag it will move about 5mm and if I let it go it will rest again on the bottom spoke. Anyone else experience this? I took it off again to make sure it was seated properly and it seems to be.
2003 Launch car : 3.0 litre E85 in Sterling grey
Hi all,
New from the forum, put the mutil function steering wheels but , mutil button not working, vehcile was not fit this equipment, already turn on the vehcile function list, vehicle is 05 build, it's looks like this case will need the retrofit cable
Will update once later on
nice write up - took me 1 month to find - nothing like this on the USA forums!
Online
Just having a quick deek through this old thread and it appears that I may need a retro fit cable for my MFSW. My car war registered on 25/09/03. What am I looking for when I remove the wheel ?? Any advice on this.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- Ducklakeview
Fred, youu can't tell by just looking when the wheel is off.
I fitted an M MF wheel to mine last night to replace the M wheel I had and the controls don't work., my car is an aug 03 build.
I believe the retrofit cable goes from the back of the wheel connector to the loom, so I think you need to remove the column cover to see.
I have the loom and will be fitting it later.
Mike
Mike
