03~05 FULL circle Brake light BRIEF
Re: 03~05 FULL circle Brake light BRIEF
I did mine a little different... Instead of just bridging the circuits I installed a nitrous delay controller I had laying around and used it to control relays to bridge the connections. This gives me the option of delaying the illumination of the inner half of the lamp once the outer half comes on. I have it set at a delay of one second right now. It is adjustable from one tenth of a second up to 20 seconds or so. I used the input from the third stop lamp to activate the controller so as not to alter the circuit voltage on either lamp which might bring on the lamp out warning light. I've been using it for six months now without any issues at all.
The controller is quite small (2"x2"x.5") so it and the relays fit nicely under the trunk liner below the right lamp access panel.
- Cool Z4
I did mine last Thursday before leaving for the holiday weekend. Took me about 15 min following the pics from the original thread. Really easy to do. Thanks.
- powerontap
did the how-to also according to original thread, easy as 1-2-3... or is that 3-2-1? Thanks BlacksapphireZ
Go Topless
- Rasalon
I did mine today the way cj10jeeper hand done it, it was simple enough but one note of caution, it's not the outside wires... its the first and the second to last... both sides have gray color wires so take the gray and the last wire on the other end and make a bridge. I did mine in 30-40 min while entertaining my 14 month old son so it' not that hard and I feel safer with more light in the back warning people that I've got the brakes on
This is a safetly feature to warn following drivers when you are braking sharply - why would you want to remove it?
- Rasalon
frankly till I got my Z, I had no Idea that If the full light came on it ment that the car was braking hard. and I doubt that I'm the only one... I always went with the old stanby which is Keeping proper distance from the car infront of you... if the car is tailing me, it wont matter how the lights com on, they will still hit me. So, If I can warn people with brighter Brake lights, I am more likely to get their attention and get them to stop earlier. Or so the theory goesDavo wrote:This is a safetly feature to warn following drivers when you are braking sharply - why would you want to remove it?
- cj10jeeper
I did not realise I had given the impression that it was the outer wires?? My posts shows photos of the exact wires I used before, during and after fitting.Rasalon wrote:I did mine today the way cj10jeeper hand done it, it was simple enough but one note of caution, it's not the outside wires... its the first and the second to last... both sides have gray color wires so take the gray and the last wire on the other end and make a bridge. I did mine in 30-40 min while entertaining my 14 month old son so it' not that hard and I feel safer with more light in the back warning people that I've got the brakes on
In terms of removing a safety device I can see that argument, but firstly I tried and could not get the inner part to illuminate whatever I did. Hard, locked, ABS working, etc. so I reasoned 'all on' is better than half and if I'm braking so hard as to activate ABS to trigger it then the guy behind is certainly going to have a job to stop as quick as a Z4 in any normal car. I also really don't think the average tailgater is attuned to 2 lights means 'sh*t' better really stop...
- RustyZ4
Thanks for this guys, did mine tonight although I had a moment, because I used the connectors, when I first did it the inner lights did not work, a bit more pressure on the connectors did it, you have to push them home quite firm, guess i was just being cautious
Z4 E85 3.0, gone but now with son
- Rasalon
No wories cj10jeeper, It just looks that way to me, no one else seems to have a problem
- Albertoxx
Finally I did it!
It took just a little screwdriver (to unplug the pins) two little wires and a couple of clamps. I didn't even solder the wires.
It's easy to recognize the right wires because on the connector they are numbered!
Did mine yesterday... quickest mod I've ever done! Only took me 10 minutes in total... and that included making a cup of coffee halfway through!
Very pleased with the results! Think is looks a million times better with both lights coming on when i break!
I'll do mine tomorrow!
2009 (59) Z4 E89 3.0i Sdrive in deep sea blue, white extended leather, I-drive, folding mirrors. Suzuki GSX 1300R Hayabusa
Quick question, the inner rear light bulb is a single filament so how can this be used as a brake light?
Edited: All done! Looks good, i also removed the pins and soldered a loop in.Thanks guys.
- cj10jeeper
I like a guy that does things the right way and solders a link in and not uses chocolate blocks or Scotchlocks*AL* wrote:Quick question, the inner rear light bulb is a single filament so how can this be used as a brake light?
Cheers Jeeper for the excellent pics and info!cj10jeeper wrote:I like a guy that does things the right way and solders a link in and not uses chocolate blocks or Scotchlocks*AL* wrote:Quick question, the inner rear light bulb is a single filament so how can this be used as a brake light?
One thing i noticed after doing this mod is that the rear lights are actually brighter than before, has anyone else noticed this?
