AUX DIY
- sk93
Re: AUX DIY
the caps don't make aux appear.. that's the cross channel resistance (by way of a resister)
the caps make a difference in which frequencies will be passed through, that's all
theorhetically, you can remove them entirely, but youd want around 1mf to get decent quality sound impo
Re: AUX DIY
It's definitely not a lack of quality, the subs behind the seats are simply not producing anything.
Re: AUX DIY
Baring in mind the cheap ebay cable I purchased, do you think its worth spending £50 on something like this?
http://www.amazon.co.uk/BMW-Genuine-In- ... B000P9Y5I4
The genuine cable from BMW?
Or is it because I have the business CD player but the upgraded speaker kit that means anything I do is going to be incredibly tricky as its an odd coupling?
- sk93
Re: AUX DIY
if you're ok with a soldering iron.. you could have a stab at making your own? it'll cost waaaay less than that.
alternatively, give your local stealer a ring first, as its around that price from them...
- thecremeegg
AUX DIY
Same here, it's bloody crap
Z4M - Interlagos Blue with Black Leather
Z4 3.0i - Sapphire Black with Red Leather - FOR SALE!
AUX DIY
I bought a cheap aux in off Amazon, came as a plain cable with no resistor or capacitors in it, bought some from Maplin and installed in cable and works perfect. Just make sure you use decoupling capacitors.
2004 E85 Z4 2.5i SE Sterling Grey.
- markplant
AUX DIY
There's a few found that out when gone to installG600 wrote:I've just gone to fit one of the recommended aux cables, turns out my car already had one fitted and tucked away being some trim, worth pulling your head unit out and checking before ordering one.
- Lynchy
AUX DIY
I appologise now if this has come up before , I've installed an aux cable today but I can't get aux to come up on my radio . I have 2 cables one which is the female end and the other the male and I've tried both but still nothing . Any suggestions appreciated .
AUX DIY
Top of the page post says:Lynchy wrote:I appologise now if this has come up before , I've installed an aux cable today but I can't get aux to come up on my radio . I have 2 cables one which is the female end and the other the male and I've tried both but still nothing . Any suggestions appreciated .
Does yours have the resister? Is it installed 100% correctly? my one could go in 2 different ways.sk93 wrote:the caps don't make aux appear.. that's the cross channel resistance (by way of a resister)
I do have an issue though, mine is no where as loud as a CD. To the point I can barely hear it with the top down. It's clear, and sounds fine, just not loud enough. Is this a iPhone limitation?
- Lynchy
AUX DIY
Hi Sam , I don't even know what the resistor looks like . I have installed it properly and I've installed one on my last Zed with no problems . Tried both cables and no difference , what does one of these cables look like with a resistor ?
AUX DIY
The one I got, had a little inline PCB with the resistor on it, then covered in shrink wrap, got anything like that? Similar to this:
I was told if it didn't have one, the AUX won't appear. The resistor bridges something so the stereo can 'see' an AUX is connected.
- Stuartt
AUX DIY
It should have a small shrink wrapped pcb in line, if it's just plug to jack it won't work.
Stuart
Stuart
2004 3.0i SE Roadster , GONE to a good home
2010 e89 35i Sdrive M sport. GONE for salvage but has been reborn
2014 e89 35is M-Sport Design Pure Traction
