Central Display- not working
bigwinn
Post by bigwinn » Fri May 24, 2024 10:42 am
Hopefully the final issue to solve on the project
Fingers crossed
The central pop up display: pops up fine, motor and case are good. Have taken it out of the car and tested it in Steves car- works perfectly.
In the project car there is no display on the screen, however when I unplug it and plug it back in I can see the screen change very slightly suggesting current is getting to it OK
As I am happy with the unit being in working order, what do we think the next steps are to sort?
EWS Delete PM me
Coding- airbags etc PM me
pvr
Post by pvr » Fri May 24, 2024 11:27 am
The screen cable goes all the way back to the navigation computer which is the source. Is the navigation unit spinning up ok?
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
bigwinn
Post by bigwinn » Fri May 24, 2024 11:55 am
Good shout
Let me check
EWS Delete PM me
bigwinn
Post by bigwinn » Fri May 24, 2024 1:45 pm
Checked. All connected.
EWS Delete PM me
bigwinn
Post by bigwinn » Fri May 24, 2024 2:07 pm
And spinning up ok
EWS Delete PM me
pvr
Post by pvr » Fri May 24, 2024 2:19 pm
Two choices, other screen to test with your computer or other computer to test your screen
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
bigwinn
Post by bigwinn » Fri May 24, 2024 2:59 pm
Time to borrow Steve’s car again
EWS Delete PM me
enuff_zed
Post by enuff_zed » Fri May 24, 2024 3:31 pm
bigwinn wrote: Fri May 24, 2024 2:07 pm And spinning up ok
Is there a disc in it?
HQ of 'Norfolk Zed Rescue'.
bigwinn
Post by bigwinn » Fri May 24, 2024 4:02 pm
Yep
Note that there is nothing at all on the display- so no radio/bluetooth menu at all
Otherwise I’d reload the v32 disc
EWS Delete PM me
enuff_zed
Post by enuff_zed » Fri May 24, 2024 4:42 pm
Have you tried another radio head unit
bigwinn
Post by bigwinn » Fri May 24, 2024 5:17 pm
enuff_zed wrote: Fri May 24, 2024 4:42 pm Have you tried another radio head unit
Not yet but the radio works fine
EWS Delete PM me
enuff_zed
Post by enuff_zed » Fri May 24, 2024 5:44 pm
bigwinn wrote: Fri May 24, 2024 5:17 pm
Hmmm. I’m not sure what goes where? Does the screen have a different input or does it get input from the head unit?
enuff_zed
Post by enuff_zed » Fri May 24, 2024 5:45 pm
Have you checked the earth?
:exitright:
bigwinn
Post by bigwinn » Fri May 24, 2024 5:47 pm
I’m not answering that
EWS Delete PM me
pvr
Post by pvr » Fri May 24, 2024 6:05 pm
Screen goes to computer, radio goes to computer. Computer seems the central point
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
