Headliner stuffing uneven?
StudioWizard
Post by StudioWizard » Thu May 23, 2024 6:33 am
Hi folks
I noticed that my headliner toward the back window feels a little lumpy. Does the filling inside the headliner attach somehow and can it become detached and bunch up or is it just lumpy?
I'm also wondering if that's why my roof doesn't open and lock completely on the first try. I usually have to open it all the way, then reverse it about 6 inches, then close all the way again before it'll actually latch. Even then, I have to push it down another inch or so or else the button flashes red. FYI: I've tried "training" the canvas corners to fold outward instead of inward so it latches more easily, but the "training" isn't really holding.
I'm wondering if I open the headliner up, reattach the stuffing or insulation or whatever it is so it doesn't bunch up, maybe that'll make the roof close more easily.
Does anyone have any thoughts about this? Also, does your top open and latch with no problem or do you also have to push it down to latch it?
Thanks for your feedback!!
Current: 2005 Z4 2.5i: first time to own a BMW and loving it!
Previous: 2018 Chevy Volt / 2004 Acura RSX Type S / 1989 Acura Intergra RS / 1982 Ford Escort / 1968 VW Bus
BumpyZ4
Post by BumpyZ4 » Fri May 24, 2024 9:49 pm
Headliner has a foam backing and after 20 year the foam starts to deteriorate.
2003 E85 3.0i Sterling Gray
KLR 650
Diva Roadster (Kit Car)
StudioWizard
Post by StudioWizard » Sat May 25, 2024 4:57 am
Could that deterioration cause problems with opening all the way and locking? Does anyone know how to replace the interior foam backing or does the entire headliner need replacing?
Thanks!
BumpyZ4
Post by BumpyZ4 » Sat Jun 15, 2024 1:46 am
Shouldn't cause any problems. Yes, you would have to replace the headliner.
KLR 650
StudioWizard
Post by StudioWizard » Sat Jun 15, 2024 7:10 am
BumpyZ4 wrote: Fri May 24, 2024 9:49 pm Headliner has a foam backing and after 20 year the foam starts to deteriorate.
Have you had to replace yours? If so, did you do it yourself?
StudioWizard
Post by StudioWizard » Sat Jun 15, 2024 7:17 am
BumpyZ4 wrote: Sat Jun 15, 2024 1:46 am Shouldn't cause any problems. Yes, you would have to replace the headliner.
Any ideas why the top doesn't retract all the way down and latch on the first try?
I've tried training the left and right "corners" of the canvas to fold outward, not inward, which has helped a little. But I still have to retract the top as far as it it'll go (usually stops 1-3 inches away from the latch), then I start closing it a little bit, then reverse again until it latches. I often have to do that 2 or 3 times before it'll go all the way down and latch like it's supposed to. It's like it's bunching up incorrectly or something... which is why I thought maybe the foam inside the headliner is causing the problem.
Any thoughts would be greatly appreciated!
