Brake issues- soft pedal ***updated with video***
Onlinebigwinn
Hi all
So a new issue with the project to sort
The brake pedal is very soft. Will go to the floor with minimal resistance. However with a few pumps it tightens up to how you’d expect.
New fluid and full bleed including ABS bleed
New hoses
No leaks
New master cylinder
Any thoughts what to check next?
I would say vacuum leak but I took the master cylinder off today after the car sitting overnight and there was a good amount of residual pressure in the system.
Thanks in advance chaps
Stuart
New hoses
No leaks
New master cylinder
Stuart
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- enuff_zed
Well now you mention residual pressure I am leaning back towards an air lock.
Forgive me for the daft question but have you definitely got the pipes on the abs unit in the right order. I know there are two different sizes so can't really go that wrong.
Do you have any ABS/DSC codes?
If it’s not leaking and you have check the vacuum. Then it must have air in the system.
2009 09 Carbon Black Cinnamon E86
Onlinebigwinn
No codesenuff_zed wrote: ↑Wed May 15, 2024 5:31 pm Well now you mention residual pressure I am leaning back towards an air lock.
And yes I did originally get the pipes the wrong way around
But at least I’m fessing up to that
So a damn good bleed needed we think?
EWS Delete PM me
EWS Delete PM me
Onlinebigwinn
Roger that
EWS Delete PM me
EWS Delete PM me
- enuff_zed
bigwinn, to confirm, when I did mine I started rear right, then clockwise round the car to the front right last. That was a conventional bleed, with the pressure bleeder, but not activating the ABS.
Then did the ABS part repeating the four corners in the same order.
For each corner I ran the abs pump twice.
If it helps, I counted ten pulses of the pump in eight seconds every time.
Onlinebigwinn
Cheers Martin
EWS Delete PM me
EWS Delete PM me
I had a similar problem with OBY after changing the brake pressure sensors. Not much fluid came out, but I must have let some air in nevertheless. I followed Martin’s bleeding guide, but with an extra hand topping up the reservoir, rather than a pump. It worked a treat.
2003 Maldives Blue 3.0i auto
In fact I didn’t run the ABS, just did the manual bleed cycle twice.
Onlinebigwinn
Thanks Ben
I’ll give it a good pump (fnarr fnarr)
EWS Delete PM me
EWS Delete PM me
- enuff_zed
If you don't disturb the ABS unit you can just do a normal bleed.
- enuff_zed
Stuart, if it turns out to be air I shall tell everyone you are 'bleeding' useless.
Onlinebigwinn
I’ve been called a lot worse
EWS Delete PM me
EWS Delete PM me
It’s possible to get air stuck in the calipers, even a thorough bleed doesn’t always shift it. Bleed while clouting the calipers with a rubber hammer has been known to shift an air lock.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Onlinebigwinn
Bearing in mind one calliper and all lines are new too
Cheers John
Cheers John
EWS Delete PM me
EWS Delete PM me
