Ahhh now that is almost too clever!
Great idea. Will do.
If you make one more post you'll be able to use the Private Messages function - it only works once you've made 3 posts.
Here is an extract from srhutch’s magic instructions:Jagcats wrote: ↑Sun Dec 20, 2020 12:10 pm Hi all
I have just tried to retrofit to my Z4 2007 2.0, which I believe is N46 engine. I purchased a new stalk and wiring kit from 2 different sellers on eBay. Both are genuine BMW items. I have completed all the wiring except for the connection to the DME, as the BMW instructions don't add up.
It states for N46 or N52 engine 'Disconnect and open plug X60002, black 26-pin, from the DME control unit' 'Connect the Blue cable (from switch) to plug X60002 PIN4'. This is where my confusion starts, both plugs are 26-pin, the Black one has an existing White/Blue wire already in PIN4.
I can see that these BMW instructions were released 10/2006 and I'm guessing that there has been a change after this date, but I cannot find any later releases of these instructions.
Does anyone have any knowledge as to where I connect this wire?
Welcome to the forum.
