Indeed
Supermarket Car park damage
- 1536Z4
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
- Reamesy
Good work mate. Try not to let sad people get you down. Just enjoy your car.
Currently; 2011 E89 23i SDrive M Sport Highline Titan Silver
Previously;
2014 SLK250CDI AMG Sport
2012 E89 SDrive 2.0 M Sport. White
2011 Audi TT Quattro
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
- Huzee4
Steve
E85 2.5 SE Maldives blue
E89 20i Estoril blue
- Nanu
Glad to see some positive outcome. Agree £40 is a paltry amount but she sounds like the type of person who would have just denied everything and drove off if you had pushed it.
You have used Menzerna to polish it out. Will be looking at giving my girl a machine polish to take out the usual light spiders webs that happen before a clay and ceramic polish. Would the stuff you have used do the job
Other recommendations would be helpful
G29 M30i M Sport San Francisco Red
Previous
E89 35is Valencia Orange
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
- MikeyH
Sadly there are a lot of people out there who just treat their cars like they are thing to get from A to B. They don’t care about their own cars, so makes them not give a shite about other people’s cars. One of my father in laws thought it was okay to scrape someone’s bumper as it was only cosmetic damage.
- 1536Z4
I think any of the main line polishes will work . I used Menzerna as that is what I had to hand . The rule of thumb is you should use a light cut polish first and then work your way up to a heavier cut if it doesn`t get the swirls out . BMW paint is/was classed as a hard paint on earlier BMW`s so I used a heavy cut as I knew some of the scratches were quite bad and then the finer cut . If you haven`t got any polishes I would go for something like Farecla G3 as it is a great all rounder .
- Nanu
Previous
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
It’s actually the other way around. Start with a G3 and work down to a 3M Ultra Fina for example.
2009 09 Carbon Black Cinnamon E86
- 1536Z4
If you are knowledgeable about the paint and the product yes but otherwise you should always start with the finest first to see if it will clear the swirls / marks and then if not go heavier and then work your way back down to the finer grade . You don`t want to be taking of clear coat you don`t need too . In my case I went heavy cut straight in as I have the experience with my paint and product to know that the finer cut wouldn`t " cut it " . It is always best to go lighter first the same as with wet sanding and then go harder if needed and then work your way back down to the finer grades afterwards . I did say that I started with heavy first and then finer in the quote below
- Nanu
My neighbour has some Menzerna 2400 medium cut polish to try before I buy.
Will this do the job and worth a try? He says it doesn’t do much of a job on his black Volvo
Previous
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
- pvr
What pad are you going to use? There are many grades in that as well, so a course pad with medium polish (I have that one as well) will do a lot more agressive polishing than the same polish on a fine polishing pad.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- Nanu
It’s yellow
Also have a grey one
Previous
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
- 1536Z4
Yellow I would guess is the harder pad and grey the softer but not always the case it depends on brand . You should be able to feel the difference . One will be harder to squeeze between your fingers . There is so much to learn about different pads and polishes . It can get very complicated . If you haven`t done it`s probably worth looking at some you tube videos first .
- 1536Z4
Yes that is fine .
- Nanu
Cheers, just checked the polisher on the internet and you are right, the grey/ black is the soft one and they class the yellow as medium. Apparently there is a red one which I’d the hardest so will have to look in the bag for that one.
Following your advice and try the softer one first with the medium cut polish then progress to the harder one if necessary. When the weather gets dryer and warmer of course.
Previous
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
