Really? What does it "immobilise" then?
E86 - Engine wont start ….update….now running.
Onlinechanlon1
Onlinechanlon1
Reading a bit more on all this and I have heard that on a manual, there is some switch under the clutch pedal that needs to be depressed in order to allow the engine to start....need to google this aswell
E86 Z4 Coupe 2006 Silver
- enuff_zed
bigwinn and I found this out when we swapped in a new DME. We didn't tell the DME not to talk to the EWS, so when we turned the key the EWS didn't recognise the DME and wouldn't let the car start. The starter turned no problem at all, but the fuel pump didn't run and I assume the DME was not 'allowed' to try to inject fuel to start the car.
- enuff_zed
Not that I'm aware of? I know on the auto you have to put your foot on the brake, but in the manuals I usually just lean in the window and turn the key. Got to be worth a try though, but surely you would have always had to do that?
- enuff_zed
Just replying to someone about something completely different and this cropped up:
It suggests you can bypass it to start the car. Worth a look?
Worth checking that the safety cut out on the battery hasn't popped.
Onlinechanlon1
Interesting…..I’ll add it to my things to look at.
Think the clutch switch thing is a no go as I recall starting the engine when I had the car on axle stands and it was in neutral and I was outside of the car when I turned the key.
Onlinechanlon1
Took a look at the battery compartment to see if it looked like the pyro fuse was at fault. (excuse the filth of it)
The photos below lead me to believe all is okay. I also took at look at Supply module 'A6009'. (Mounted on the front of the main ECU box).
Whilst there was around 10 or so individual fuses inside, none of them had blown.
Going to go and try to bench test the old starter now....
Onlinechanlon1
okay - so just after testing the old starter motor.
See below video. Looks fairly good to me.
So given the car refused to start with this motor in it, I can concur that the new motor has no affect on things, and there must be some relay/fuse/module/dodgy wire somewhere else.
I should also mention that the car doesnt start with the spare key either.
I thought I read somewhere that if you hook up a battery to the positive/negative terminals in the engine bay, where you would jump start the car, that that may allow you to start it?
Any one heard that?
Any one heard that?
- enuff_zed
Looking at the wiring diagram I posted that makes sense if it is the supply from the alternator that is the issue. Still relies on the solenoid being actuated via the EWS thoughchanlon1 wrote: ↑Thu Apr 25, 2024 8:16 pm okay - so just after testing the old starter motor.
Any one heard that?
I’d try cleaning those battery terminals first.
F20 M135i - current
E86 Z4 3.0 Si - looking for one
Previous BMW's: 1M,130i, E90 M3
Previous others: Cayman R, Exige V6, TVR’s (T350c, Griff 500, Chim 500), 182 Trophy, 306 GTi-6
Onlinechanlon1
Not sure I follow. So I hook up a battery to the terminals in the engine bay, but I still need to hit the solenoid wire on the starter? Or would turning the key do that?
I would have thought it should send a signal to the starter?
- enuff_zed
Ah I was thinking that you connect to the points under the bonnet and turn the key. If it starts it points to the feed from the alternator being the issue.
Onlinechanlon1
Thanks for the confirmation.
I’ll attach my spare battery to the engine bay poles tomorrow and see what happens when I turn the key. If it fires up, you may hear loud squealing coming from across the water
- Z4Mariner
I don't want to interupt the flow here, because it's not likely your issue - Chanlon1, you heard correctly that there's a Hall effect sensor on the clutch for MT cars - at least for LCI cars in the North American market. My car has one. It's solid state, and failure should be infrequent, but miss-alignment, a clutch pedal with too much slop, or connector issues could cause faults. IFAIK failure for this circuit should produce a no-click, no-start.
Z4Mariner
Minnesota, USA
2006 Z4 Coupe 3.0Si, Montego Blue, MT
Minnesota, USA
Onlinechanlon1
No worries. I appreciate the input.
I am 99.9% sure I don’t have such a switch now. Recently I had the car up on axle stands and I am fairly sure on a few occasions I reached in, put her in neutral and started the engine without sitting in it, therefore not putting the clutch in.
