Hi,
Will a 8.5jx19 with an ET of 38 stick out to much on the Z4M
wheel offset
OnlineMr Tidy
wheel offset
No, if anything it will sit further in than the standard 224 rear wheel as that is 9J x 18 ET30.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
wheel offset
If it's for the rear (OE is 255/40r18 et30) - a bit too close to the strut for me:
https://www.willtheyfit.com/index.php?w ... offset2=38
If it's for the front (OE is 225/45r18 et42) - it's almost identical:
My other concern would be the extra inch to 19" from 18", as the wrong tyre size could cause more fouling.
wheel offset
https://www.zpost.com/forums/showthread.php?t=87131
https://apexwheels.com/fitment-guides/b ... ment-guide
Short answer is think you'll be ok if you stick to a 245/35 or 245/40 profile tyre. (Assume you're referring to front axle.)
wheel offset
Must be talking about the front.
They will fit just fine
2009 09 Carbon Black Cinnamon E86
wheel offset
sorry for the late replies.
Yes it is for the front
Rears are 265X30X19 AND ET 33
