Top hose leaking. Already replaced. Any tips?
BigDaddy
Post by BigDaddy » Wed Apr 24, 2024 6:11 pm
Hello everyone. I bought a Gates hose to replace the top hose that goes into the radiator/expansion tank. The problem is where it meets the expansion tank, the metal clip is in but water is leaking out of there anyway when the car gets hot. Is there an easy solution to this? Buying a new hose was supposed to solve this problem!
I have looked and seen the OEM replacement is £85 and this one was £30. Have I just got to bite the bullet?
2004 E85 3.0 Sterling Grey
j3nks79
Post by j3nks79 » Wed Apr 24, 2024 6:47 pm
Did it have a new o ring with it?
2009 09 Carbon Black Cinnamon E86
BigDaddy
Post by BigDaddy » Wed Apr 24, 2024 7:39 pm
I’m pretty sure it did. It did seem to be sealing ok but then I have had the cap off a few times recently as have been flushing the cooling system etc and the twisting motion of the cap coming off and on seems to have slightly buggered the seal.
Does anyone have any recommendations for any o ring kits? I don’t know the size of the o ring that’s all but there are some kits on Amazon that contain a few different sizes.
j3nks79
Post by j3nks79 » Wed Apr 24, 2024 8:31 pm
I’m pretty sure you can buy it on its own from the Maindealer.
Check real OEM
BigDaddy
Post by BigDaddy » Thu Apr 25, 2024 12:21 am
Found the size. 16mm ID x 3mm width. Ordered a pack of 5. Just thought I’d update the thread in case anyone else has the same problem. Hopefully a new one will fix it.
colb
Post by colb » Thu Apr 25, 2024 8:05 am
Put some silicon on your finger and run it around the O ring before putting the hose back in so there is no chance of it getting pinched when the hose is slid in. Bit applied to the hose stub also a good idea.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
enuff_zed
Post by enuff_zed » Thu Apr 25, 2024 8:15 am
Twisting the cap off shouldn’t even touch the pipe?
Are you sure it is pushed completely on? It takes a good push for the last couple of mm.
HQ of 'Norfolk Zed Rescue'.
BigDaddy
Post by BigDaddy » Thu Apr 25, 2024 10:39 am
If I twist the cap the expansion tank moves slightly and I can hear pressurised air escape from the small pipe. I don’t know whether the tank is supposed to be completely solid and not move, but mine isn’t.
I’ll try and lube up the ring before I shove it in next time.
enuff_zed
Post by enuff_zed » Thu Apr 25, 2024 11:08 am
BigDaddy wrote: Thu Apr 25, 2024 10:39 am If I twist the cap the expansion tank moves slightly and I can hear pressurised air escape from the small pipe. I don’t know whether the tank is supposed to be completely solid and not move, but mine isn’t.
Ah I see.
But even then it shouldn't unseat the seal.
BigDaddy
Post by BigDaddy » Thu Apr 25, 2024 11:26 am
Yeah, I know it shouldn’t. Well I’ll see how the new ring works. One day I’ll get to the bottom of all these niggles I hope!
enuff_zed
Post by enuff_zed » Thu Apr 25, 2024 11:34 am
Only other option is if it's a badly made expansion tank. No chance that outlet is damaged is there?
BigDaddy
Post by BigDaddy » Thu Apr 25, 2024 4:10 pm
I do have a spare expansion tank if that one is shagged but hopefully it won’t come to that. I’ve just taken a look at it and the large pipe is tight and the smaller one moves a bit. A tiny bit but that’s all it needs I guess.
Will see how it goes. I’ve used so much coolant doing jobs on this car, seems like a lot of jobs involve removing coolant hoses! Ah well, needs must.
Big Bad Boris
Post by Big Bad Boris » Thu Apr 25, 2024 6:41 pm
[/quote]
Sound advice indeed :oops:
BigDaddy
Post by BigDaddy » Fri May 03, 2024 5:47 pm
Just to finish this thread off I replaced the thermostat today and while doing that took the hose off the expansion tank. There wasn’t an o ring in the small pipe. Whoops! Have now put one in and the connection is much firmer now.
Basically I’m an idiot. But at least it’s sorted now and for pennies.
enuff_zed
Post by enuff_zed » Fri May 03, 2024 6:08 pm
BigDaddy wrote: Fri May 03, 2024 5:47 pm Just to finish this thread off I replaced the thermostat today and while doing that took the hose off the expansion tank. There wasn’t an o ring in the small pipe. Whoops! Have now put one in and the connection is much firmer now.
Good result, and hardly an idiot as you would expect a new pipe to come with one fitted.
A cautionary tale for us all though. I will check every hose I replace from now on. :thumbsup:
