My 2006 Z4 Coupe
My 2006 Z4 Coupe
I didn’t get to charge into sorting the suspension out on the car this weekend due to poor weather last night and other distractions, including this one’s arrival
I also received a text to say that my refurbed wheels were ready for collection so I headed over to pick them up because it was easy to steal my wife’s E91. This is where this update might get a bit controversial….
I’ve never liked the 108’s but I struggled to find other options so ended up with a set of 261’s which I picked up last weekend. I decided to be a bit braver than silver / pale gunmetal so opted for a satin gold. I chose a colour which looked quite pale in the paint catalog (in my head I was thinking Porsche gold rather than something bolder like Ferrari gold). Upon arrival I had a bit of an oh s**t moment because they were much closer to the latter than the former particularly under the harsh light at the painters.
Anyway, I paid and took them home to get them ready for fitting with some trepidation. First up was a quick clean before applying a coupe of coats of Alien Magic ceramic spray. At this point, they were still looking very very bright.
It was then time to fit them.
Seeing them against the dark blue paint a made me start to feel a bit more at ease. It’s certainly quite bold, but I think it works.
It was then time to take a few better pictures but the colour proved quite difficult to capture accurately with a phone - it often looked really yellow. These are a few that look vaguely like it does in real life.
Whilst the outcome is a bit different to what I initially had in mind and it wasn’t love at first sight when collecting them, I’m actually pleased with how they’ve turned out. The colour works with the dark blue and suits the unusual shape of the car, but I’m well aware that they’ll be a bit marmite.
- Mr Tidy
My 2006 Z4 Coupe
It's good to see something different and the colour works well with your dark blue car.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
My 2006 Z4 Coupe
Good to see you on here, Sam.
We move in similar ways.
130i Limited Edition to Z4 Coupe with 216 wheels.
Are we seeing you at Gaydon this weekend?
E86 3.0si - Koni, Eibach, Eisenmann. viewtopic.php?t=143973
F31 340i MPPSK - Carrying family, bikes, kayaks and everything else.
My 2006 Z4 Coupe
Cheers mate.
Unfortunately I can’t make Gaydon this weekend due to catching up with family. Well have to get a C&M dinner sorted…
My 2006 Z4 Coupe
Since having the car, it’s always had a tendency to tramline. Sometimes it’s ok, but other times it’s quite bad. It’s better since ditching the sh***y Dunlop tyres it came with.
So today, I set about replacing the front wishbones, drop links and ARB bushes. It took longer than anticipated because the nuts for the middle ball joint on the front wishbones was larger than I thought / read online. I had to make a mast minute dash to Halfords for a 22mm spanner and Sod’s Law, my local store didn’t have one in stock, so I had to go a bit further afield.
The passenger side was dead easy because access is better but it’s a pain in the bum on the drivers side because of an engine mount which restricts you to teeny turns.
I fitted the following:
To improve access to the middle nut on the drivers side, I dropped the whole ARB (which is a bit crusty).
And all fitted.
It was my first time getting up close to the underside of my car, and a few things were spotted.
- Moog wishbones
- Moog tie rod assemblies
- Mood drop links
- Powerflex ARB bushes
And all fitted.
- Access flap for the oil drain plug is missing so I’ll get one ordered
- Oil sump is weeping ever so slightly
- Passenger side disc was missing the retaining screw and it turns out the thread is shagged and very rusty. I’ll see if running a tap through will save it, if not the front hub will get replaced at some point
- The fan had previously been removed and whoever fitted it missed the various groves and clips lower down so it was flapping about. This has been refitted properly now
My 2006 Z4 Coupe
Having replaced a few bits on the front end, I set about working on the rear end on Sunday. I was supposed to replace the rear drop links but I decided it was too much of a ball ache, especially with some of the bolts being so crusty. Access isn’t the best around the back end on these.
When I took the car for an alignment originally, the chap doing it was wary of adjusting the rear because the carriers for the RTAB were pretty crusty (he did show me) and the bolt heads didn’t look too clever, but they same out without too much fuss, I think one needed the socket forcing onto it.
Passenger side carrier free.
The bush looked a bit scabby.
The tool used for pressing out the old bush was an eBay special.
I needed to use a breaker bar on the tool, with the arm braced against the car with some wood and supported by a jack to stop it moving too much. It did come out though.
I had planned to use Powerflex Heritage RTAB, but they didn’t seem to fit into the arms very well and I couldn’t find a way to get the carriers over them whilst keeping the, in situ so I gave up and used the normal Powerflex bushes which seemed easier to install.
Once the passenger side was buttoned up, it was time to crack in with the drivers side. The carrier this side seemed far crustier.
The bush was also much more tired.
It was also much more of a sod to get out, requiring a lot of force.
The car was aligned on Monday and generally feels much better to drive. It’s nowhere as planted though as speeds pick up compared to my old 335i although that was running extra front camber plus as many M3 arms that would bolt on. It was also set up by String Theory, so I think I’ll treat this to a better quality alignment.
Onlinechanlon1
My 2006 Z4 Coupe
That's a neat idea for the base of the axle stand to sit in and not damage the driveway.
E86 Z4 Coupe 2006 Silver
My 2006 Z4 Coupe
I ticked off a few little jobs last night.
The trim above the radiator was missing a few fixings, so these were replaced.
Whilst the plastic trim was off, I treated some surface rust with Jenolite. Giving that removing the whole piece looks like a big undertaking, I’ll just tidy it up with some Hammerite in due course.
Next up was replacing the access hatch for the sump plug.
The car was then washed, just in time for today’s forecast downpour. Joy.
I did notice a few more fixings missing in the engine bay, so these have been ordered.
I’m found to change the passenger side wheel bearing because the thread for the disc retaining screw is knackered. Whilst the bearing is off, I’m going to replace the dust shield which is currently held in place with zip ties. After that I can fit my new ATE discs and ceramic pads. The current pads create a lot of dust, so I can’t wait to change them.
My 2006 Z4 Coupe
I’ve ticked off a few more jobs over the last few weeks.
First up was to pop a couple of coats of Hammerite over the rust converter on the front panel. It’s brush applied but looks better than rust in my opinion.
Panel exposed ready to be painted.
Masked up for painting.
Painted
Everything back together
Whilst I was fiddling in the engine, I decided to change the air filter. The old be was pretty grotty.
New one fitted.
I also cleaned out the airbox which was full of crap.
Painted
New one fitted.
My 2006 Z4 Coupe
Over the weekend just gone, I noticed that the outline of the Z4 badge could still be seen in certain light so after washing the car, the back end was polished again.
Later that night we headed out for a drink since we had a rare child free night and the car looked lovely in my biased opinion.
My engine cover was missing a few of the fixings that old the beauty cover to the frame underneath. Not a big issue but still annoying.
New ones arrived the other day, so we’re suit fitted.
My 2006 Z4 Coupe
I had to pop to ECP to pick up a bearing puller so I can change my passenger side front wheel bearing so bought a micro filter whilst I was there.
Upon removing the old one, I was very glad that I did. Even more detritus fell out after poking around the opening.
Old and new
The old one was a genuine BMW part dated March 2007, so I’m guessing that it hasn’t been changed for a very very long time.
Old and new
My 2006 Z4 Coupe
That blue is well nice, Sam.
