Good Evening everyone!
I searched through many forums trying to figure out how to code the RHD motor to a LHD steering rack to no avail..
Does anyone know how to do such a thing?
Thanks in advance to everyone
Coding a RHD EPS Motor to a LHD Steering rack
- enuff_zed
Hello, I suspect it is the same issue that the Z4 has. The motor is mounted on the opposite side of the column so has to rotate in the opposite direction. Therefore when you turn left it wants to turn right.
I have no idea if this can be coded or whether you will need to find the correct part.
