Hi..
Is this going to be expensive..
The following code jumped up today after 10 mins driving it also appeared last Thursday but have not driven the car since
- DME active codes -
29F2 - DME: Fuel high-pressure system, fuel pressure.
Its on a 35i
29F2 Error Code
Online
29F2 Error Code
2010 Black E89 35i
- Deepseaskateboard
29F2 Error Code
If you search the fault code on here it will take you to another thread regarding the replacement of the high pressure fuel pump, but could also be injectors or the low pressure pump.
Best thing is to get it diagnosed, looking at the other post for a high pressure pump it could be around £1500ish.
Online
29F2 Error Code
Thanks for the reply..
Drove home yesterday and back to work this morning and no codes.
2010 Black E89 35i
- Deepseaskateboard
29F2 Error Code
Hopefully you dodged a bullet!Gingerlomax wrote: ↑Wed Apr 10, 2024 11:31 am Thanks for the reply..
29F2 Error Code
I doubt it.
HPFP seems to pop up once or twice, then dissappear. Then pops up more & more frequently over the coming weeks / months before it ultimately fails.
Clock is ticking.
Clock is ticking.
Online
29F2 Error Code
Could it be the pump in the fuel tank?? Mine has been noisy since i owned the car.
2010 Black E89 35i
29F2 Error Code
Technically could be the HPFP or LPFP or injectors - or a mixture of any of the above.
There is a weakness in the HPFP on these cars that is quite well documented if you do a search, but just because that is quite common doesn't automatically mean yours is failing.
If you can, I would try & get a detailed scan done that might give more details.
Online
29F2 Error Code
Hi Again.
Back from the garage and as you all suspected it looks like the HPFP is on its last legs. Speaking the the mechanic he said I could probably do it myself as it's not really a hard job just takes time to get to it then. Has anyone got a vid or a walkthrough. There are loads on YouTube for 335i.
2010 Black E89 35i
