I've started getting a warning for brake pads servicing coming on when i start up. Doesn't happen every time, but started a week or so ago.
I don't 'think' the pads need replacing but will check them over at the weekend if i get a moment.
However, checking the service indicator it shows 1100miles remaining. I tried resetting this but i can't get it to reset (the method works for all the other service indicators)
Is the miles remaining actually calculated from the sensor reading or should it reset?
Brake pad service light reset
- B21
If the pad sensor has been triggered by burning through the elements then it needs a new sensor to reset it..check your pads..and sensor
Thanks...will check when i get a bit of time off work!
- Chippie
You may also need to disengage the handbrake when resetting the indicator
I had exactly the same a while back, didn't always come on, loads of wear visible on the rear pads.
Sometimes it appeared if I'd parked with two wheels on the kerb.
It was a duff rear brake sensor even though it hadn't worn at all, looked fine
The pad sensor and 'computer' are not linked. The computer mileage 'guess' for pads is a pre-programmed generic estimate and uses mileage of the car and other driving data to give an idea.TheOneAndOnlyTinTin wrote: ↑Mon Mar 25, 2024 9:18 pm Is the miles remaining actually calculated from the sensor reading or should it reset?
The sensors are physical which make a circuit when they come into contact with the disc, so are your 'last line of defence' as it were.
Always find it best to ignore the computer and disconnect the sensors (but keep an eye on pad wear). More trouble than they are worth IMO.
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
