My 2003 2.5 has a flickering oil light at idle when I stop for a stoplight. Not always, and only when the car is hot.
I Checked the oil level and things are good.
Watching this YT video, this guy says it could be Oil Pressure sensor, Oil Pump or tolerances.
What do you think? Is he right?
Anyone ever have a flashing oil light, and if so; How did you resolve it?
https://youtu.be/cTRzCFsaSqY
Anyone solve the Flickering oil Light problem?
- DashingDaryl
Is it red? Could be a faulty pressure switch. I’d start with that.
If that doesn’t solve it you may have an oil pressure problem. When did it last have an oil change? The filter can collapse and cause problems.
If not could be an oil pump. But one step at time and start with the easy stuff
2009 09 Carbon Black Cinnamon E86
- DashingDaryl
Thanks, I have a Hella Pressure switch on order and will start there. Thanks for the info on the oil filter. Never considered that..
- DashingDaryl
After replacing my oil pressure sensor, the problem went away and hasn't returned. It was a pretty easy replacement.
- colb
Quite rare for these sensors to fail but the can go weak, had one on an Austin 1100 many years ago that started the light flickering, replacement sorted that.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1998 Honda Deauville 650
1999 1.8 Z3
2003 2.5 Z4
