Hi all. I have an intermittent fault on my 06 2.5 . Occasional rough idle. The code reader told me 2A82 DME VANOS INTAKE.
I replaced the solenoid with a new Febi Bilstein one - still got the scars - it is the upper one, isn’t it ?
Cleared codes, all seemed good, but it stalled a couple of times. The same 2A82 code comes back. The engine runs and pulls well otherwise, no engine management light on.
I did replace both post cat lambda sensors before this, with new Bosch ones.
Any good ideas please
Intermittent fault ? Vanos
- enuff_zed
N52?
Look up my thread on Project Spa.
Hope it doesn’t upset you too much!
Ooh, that’s not a happy read !
- enuff_zed
But it does give you some other stuff to look at.
Indeed, and thanks.
Funny thing is, the car drives fine, no warning lights, etc. I shall drive it daily and see what it does. - also known as burying your head in the sand !
- enuff_zed
Well as you can see, if I can use the project car through April and prove it runs ok then it may still go to Spa.healeyneil wrote: ↑Thu Mar 21, 2024 12:28 pm Indeed, and thanks.
I think I have solved my problem. I bought a new oil filter cap. When I removed the old cap, the centre insert, with its little O ring, was completely missing. With the new cap fitted, after a couple of spirited drives, I have no codes thrown up.
I’m fairly sure this bit has been missing from the oil filter housing for 5 years though, so who knows.
Anyway, right now I’m a happy bunny
