Easily done with those diagrams I nearly ended up ordering the wrong seal for the windscreen when I replaced that .
Coupe roof seals - Discontinued
- 1536Z4
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
Is this another part on the Coupe that I need to add to the 'watch it' list. ?
E86 3.0si - Koni, Eibach, Eisenmann. viewtopic.php?t=143973
F31 340i MPPSK - Carrying family, bikes, kayaks and everything else.
- 1536Z4
You will probably not have a problem with them it`s just because I took the roof off and decided to change them at the same time . They may well have lasted for years without issue but they were a bit tatty so I decided to replace them before finding out they were discontinued . I`m going to mask the roof line off and use some Geocel marine silicon rubber .
Got it, thanks for the info..
