Airbag Resistor
Airbag Resistor
Hi everyone!
I was hoping to see if someone else has had this issue...
My airbag light has been on for almost a year and now my MOT is around the corner!
I've had the car diagnosed and it is a faulty airbag resistor (low voltage) on the passenger side. (Error code 93E7 SIM)
I'm struggling to find a garage willing to sort the problem. The part looks relatively cheap online, but I can't find clear information on the location of the airbag resistor... I've also read that sometimes a bypass is installed on the airbag system? Which could be the case for mine as the roof motor was relocated prior to me buying the car.
ALSO, I have a lot of water ingress in passenger side from the roof cavity which I'm guessing may have caused this issue. I've had piper cleaners up the drain plug hole, got some gunk out but it's atill not draining so I'm guessing it's also blocked from above!
Any tips?
Thank you!!
Any tips?
Thank you!!
- bigwinn
Airbag Resistor
Morning
Where you based?
I’d say the issue is water ingress probably from a failed door membrane will have killed the module- is the area under the seat damp?
I wouldn’t try to bypass the airbag unless it’s the last option- best to get a new module and code to the car once you have sorted the water issues!
Stuart
Where you based?
Stuart
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- enuff_zed
Airbag Resistor
If it's all wet on that side then it could possibly be the left airbag module, that sits almost on the floor at the base of the B-pillar.
Whip the carpet up in that corner and see if it is wet, or corroded around the plugs.
(This is assuming it's a pre-facelift?)
If you can define exactly which component is at fault then I can possibly help you out.
I have a few modules here, but would need to double check against your part number.
I can fit and recode in 2 hours or less.
I'd suggest a good search on the forum for that code.
For example, bigwinn found his was just a dodgy connection.
Airbag Resistor
Thank you for the speedy replies!
I'm based in Kent and my z4 is a 3.0l manual 2003 plate.
I'm currently at work so I'll have a look into the connections this evening. Should I disconnect the battery while looking? Thanks a lot for your tips! I will reply once I've had a rummage.
- bigwinn
Airbag Resistor
Deffo disconnect the battery when dealing with airbags and let them sit for 20 mins
The other issues I’ve seen connection wise are in the door connector where corrosion causes pin issues
EWS Delete PM me
EWS Delete PM me
- enuff_zed
Airbag Resistor
Don’t disturb any airbag plugs with the battery connected. It will give you even more faults. Disconnect and wait twenty minutes.clubinmonkey wrote: ↑Mon Mar 11, 2024 10:48 am Thank you for the speedy replies!
If you prise out the coin holder behind the handbrake you can just about get at the plug on the centre module (SIM85).
I’m a couple of hours from you but if you need a module sorting let me know.
However it will have to be after 25th March as I’m away on holiday.
Airbag Resistor
bigwinn, enuff_zed. Out of interest, why wait 20 mins after disconnecting the battery? Do the modules have an internal power supply, or is it a case of letting any residual charge in capacitors dissipate?
2003 Maldives Blue 3.0i auto
- enuff_zed
Airbag Resistor
Dunno. Except a BMW tech told me ten minutes and I’m doubly cautious
- bigwinn
Airbag Resistor
I think it’s about ensuring any residual current (and maybe even static energy) is out of the system. I don’t think there are any capacitor type products in the circuit but it makes me feel safer
EWS Delete PM me
EWS Delete PM me
