Will they fit(wheels tires)
Will these wheels and tires(see link below) fit on the rear end of my e89 z4?
https://www.wheel-size.com/calc/?wheel1 ... 0mm&sr=0mm
- Mr Tidy
Welcome to the forum.
If your Z4 is also an E89 there's no reason why they wouldn't!
If it is an E85 or 86 they might. I fitted a set of staggered 18s with the same offsets from an E89 to my previous E86 and they were fine, but the rears were 8.5J not 9J like those Style 296 wheels.
Hopefully someone might know.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Sorry I wasn't clear. The pictured E89 is mine and I just posted it for the sake of it. I want to go from a 255/35/19 rear to a 285-305/35/19
The new wheel would be 19x9.5-10.5 with an offset of 10, up from a 19x9 offset 40 wheel.
I have a fitment link in the OG comment but I think I placed it oddly so you didn't see it. I'll edit it.
- Mr Tidy
Oh right, your proposed set up sounds pretty aggressive but as I've only had E86s I can't help with that.
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Even 9.5 ET 10 with your current tire won’t work. 9.5j rears with an ET of circa 33 are just about do-able from memory with 255/35/19’s, but even a set of 437M’s which are 10j ET 40 on the rear will rub with standard size M3 tires. You’d probably get away with 275/30/19’s on 10j ET 40 - but 9.5J ET10 can’t see the rim even sitting within the wheel archNeo Zeon wrote: ↑Mon Mar 11, 2024 12:09 am Sorry I wasn't clear. The pictured E89 is mine and I just posted it for the sake of it. I want to go from a 255/35/19 rear to a 285-305/35/19
Just looked at your link, basically the rim will sit 5CM or nearly 2 inches further out from the arch than 9J ET 40
Previous Z4’s :E89 30i, E89 20i, E85 3.0Si (X4) E85 3.0i, E86 3.0 Si, E85 2.5si, E85 2.5i
- Mr Tidy
So you probably need to read B21s 35is Build Thread - if you haven't already!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Darn back to the drawing board. The current rears are 255/35/19(OEM) and I did fit those M4 666m wheels on the back( didn't drive it around) and it sat quite snug, or at least I thought it did.True-Blue wrote: ↑Mon Mar 11, 2024 12:56 amEven 9.5 ET 10 with your current tire won’t work. 9.5j rears with an ET of circa 33 are just about do-able from memory with 255/35/19’s, but even a set of 437M’s which are 10j ET 40 on the rear will rub with standard size M3 tires. You’d probably get away with 275/30/19’s on 10j ET 40 - but 9.5J ET10 can’t see the rim even sitting within the wheel archNeo Zeon wrote: ↑Mon Mar 11, 2024 12:09 am Sorry I wasn't clear. The pictured E89 is mine and I just posted it for the sake of it. I want to go from a 255/35/19 rear to a 285-305/35/19
Any suggestions for a 19 inch wheel setup for between that 285-300 mark for the rear? Do not mind poke out from the sides.
- B21
265/30R19 front
285/30R19 rear
Is about the limit and even that requires some massaging of the inner liners..
9j 10j
ET25 ET30
285/30R19 rear
9j 10j
ET25 ET30
A very modified Atacama Yellow 35is Previously a slightly less modified Atacama Yellow 20i MSport
Ahh the 35 sensei! Seems like my final build goals are similar to what you ended up with so I'll be focusing on your journey. As I alluded to earlier I bought a set of pure turbos and am looking to press out to 600 HP. Also going for a qaudtip exhaust and maybe some nice cosmetics for the headlights. Already upgraded the breaks to a BBK set. Not the place I suppose to talk about this but any tips feel free to send them my way via PM.
I'll look into those wheel sizes thanks!
Shame I just bought the 235/35/19 fronts 2 days ago ( up from the 225s) because a crazy person slashed them.
Cheers.
- B21
If you pm with your FB messenger or WhatsApp we can chat FOC..Neo Zeon wrote: ↑Mon Mar 11, 2024 10:16 am
Cheers.
235/35 19 is not a bad tyre to go with a 275/30 19 rear
- tiglon
275/30/19 will also be fine on the rear with ET40.
2014 E89 35is Valencia Orange 788M wheels (M2 Competition), E90 M3 control arms, Eibach Pro Kit Springs, MHD Stage 1
- B21
Not necessarily so…
On 437M with 275/30 MP4S yes..on 437M with 275/30 SC7 no…just fitting 10mm spacers to rear
- tiglon
Fits well on 788M, SC7 tyres. I thought 788M was exact same size and offset as 437M, but perhaps not?
