Guys, I noticed the other day that I'm missing a small flap/guard on the underside of the bonnet, offside.
I have one on the nearside.
I've been through RealOEM but cannot seem to locate what it is, or find a part number.
The underside of the bonnet has small holes for the attachment.
Any ideas?
I'm missing this part under the hood.
E86 3.0si - Koni, Eibach, Eisenmann. viewtopic.php?t=143973
F31 340i MPPSK - Carrying family, bikes, kayaks and everything else.
- enuff_zed
Don't think you are.
The mounting point is for LHD versions.
Could this be the part? Seems to be only single sided though due to where in cabin air intake is.
Part no. 64116924539 - item #1 below
https://www.realoem.com/bmw/enUS/showpa ... Id=64_1365
https://www.ecstuning.com/b-genuine-bmw ... 116924539/
Thanks guys.
Yes, I've since spoken to a mate with a Coupe and he has the same situation. 1 flap on the passenger side, nothing on the drivers side.
I immediately assumed something was missing as I've found so many other little clips and screws missing from under there.
Case closed.
Thanks.
Case closed.
Thanks.
- 1536Z4
You seemed to have gained some sound insulation though
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
Ahh yes.. I was wondering if anyone would notice.
A little experiment with the left-over insulation from when I did the interior.
I'm due to get the rear arch liners off soon, so will get under there, too.
I think I'm going to try and cover the arch liner, inside. As in the outside, gahhh, you know what I mean.
- 1536Z4
