This is mine, so its literally rubber on metal/glass.....
Rubber trim around the windscreen
- chanlon1
E86 Z4 Coupe 2006 Silver
- darich
Still don't see the issue.
Proper trim removal tools is all you really need. As I said, I changed my E86 trim in under an hour having never tackled it before.
Previously 2004 Sterling Grey E85 3.0SE
Currently 2007 Silver Grey E86 M Sport
Instagram - Zed4Coupe
- patriot66
I agree. I used two plastic trim removal tools, microfibre cloths and plenty of Tar and Glue Remover solvent to clean any excess screen sealant from the recess and rear edge of the glass. Took me 45 minutes to an hour of cleaning and then the trim went in first time, a bit of adjustment at the top corners and done in 10 minutesdarich wrote: ↑Tue Feb 27, 2024 11:16 amStill don't see the issue.
My window trim is in but for some reason there is now wind noise coming from the passenger side at motorway speeds. It sounds like it’s the top of the window trim all the way over to the left. The new trim is a way better fit than the old trim which was falling apart so I don’t know why it’s making a noise.
I’ve been over it and it all looks like it fits perfectly well and I can’t see a single hole anywhere so no idea why this has suddenly started.
If anyone has any ideas on what to adjust to stop the damn noise that would be great.
2004 E85 3.0 Sterling Grey
- pvr
And bump and the smallest of gaps will do that. I solved 75% of the wind noise but still have to fix the rest, I use the windscreen gunk goo stuff (can’t remember the name, but some sort of bonding) to stick the rubber down so it doesn’t protrude anywhere
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
You know what as I read your post it has made me wonder whether it looks completely tight, until the point where wind is blowing against it at 70mph then it starts to lift. I will put some duct tape over it today to test it then if it stops the noise I’ll have to squeeze some sealant under there.
- pvr
I put masking tape over the whole top section to test and it was completely silent. Don’t use duct tape as you will pull everything off with it
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- darich
I was similar. I was about an hour to remove, clean up, fit, remove to adjust and refit.patriot66 wrote: ↑Tue Feb 27, 2024 8:28 pm I agree. I used two plastic trim removal tools, microfibre cloths and plenty of Tar and Glue Remover solvent to clean any excess screen sealant from the recess and rear edge of the glass. Took me 45 minutes to an hour of cleaning and then the trim went in first time, a bit of adjustment at the top corners and done in 10 minutes 20230602_160457.jpg20230602_160507.jpg
No issues at all....and I have an E86
Well the windscreen trim is not the problem it’s the passenger side window not sealing very well against the roof. It looks like maybe the back of the window needs to lift a little. The drivers side doesn’t seem to have a gap but there is a bit of a gap on the passenger side.
