Oil pan removal for S54
Hello,
I'm trying to do rod bearing swap myself using jack stand. I see some videos for M3. Not at all for Z4m. Any steps or details witth photo/videos to remove oil pans?
Here is the link of sound
Valve adjustment, vanos rebuild, cam shaft, rocker arm replacement were done. Is this noise coming from rod bearing? Or what can cause it?
https://youtube.com/shorts/vjVnohU0fC8? ... MM2REZehDB
Updated:
Better video here
https://youtube.com/shorts/ZvvYnqEh-n8? ... zFkmz7YI-a
Updated:
Better video here
A video inside the engine bay would help to identify the sound. Could be a timing chain rattle. https://www.zpost.com/forums/showthread.php?t=607732
That sounds like a rocker arm to me, I think rod knock is more of a thud - have you checked the oil filter at all to see if there are any metallic flakes / debris?
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
Hello, I will take a new video inside of engine bay and each part.raymond.harper wrote: ↑Thu Feb 08, 2024 7:41 am A video inside the engine bay would help to identify the sound. Could be a timing chain rattle.
Hello, I recently purchased with new valve job+ rocker arm done + new oil changes, so I never tested yet. Any idea how much sample I need to take for blackstone lab? if it is small amount, I prefer to send it..Simon 3.2M wrote: ↑Thu Feb 08, 2024 10:53 am That sounds like a rocker arm to me, I think rod knock is more of a thud - have you checked the oil filter at all to see if there are any metallic flakes / debris?
OnlineMr Tidy
Doing rod bearings is a pretty major job.
As I understand it the front crossmember has to be removed to get the sump pan off, which means supporting the engine from above and is probably why it makes sense to fit new engine mounts at the same time.
I had my bearing shells and engine mounts replaced at 78K miles, but I've seen worn shells at around 50K and others no worse that had done over 100K!
Good luck anyway.
Good luck anyway.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Online
I did mine on axle stands in a single garage
Front cross member down
which has a lot of stuff bolted to it
The worst bit of the job is the engine oil dripping on you
To avoid this I removed the oil pan one weekend and cling filmed the bottom end to keep any dust and grit out, then the next weekend did the job
PM me if you want to talk you way through the job
Thank you. Many Many questions... I sent you PM.PDJ wrote: ↑Thu Feb 08, 2024 10:58 pm I did mine on axle stands in a single garage
Online
As I was dinging a lot of work on the front of the car I removed as much of the parts that bolted to the cross member as possible
I did remove the steering rack as well I can not remember if this needs to be removed or not
I will look back at my photos
If you search my posts by my user name it is all in the thread what have you done to your car
When you remove the oil pump to get at one or two of the rod bearings the relief valve needs checking it is integral to the oil pump so if it is worn it is a new pump or blank it off and fit an adjustable relief valve external to the engine
- abar121
As above, that doesn't sound like a rod bearing, more top end.
'07 Z4M Interlagos Blue. All options except extended leather.
OnlineBeedub
sounds like a worn follower type noise....
Here is a new video clip. Definitely. It is coming from the top. Is it good to start to put a new tenionser?
