CarPlay Retrofit
CarPlay Retrofit
I have recently bought a 2010 E89 and want to add CarPlay functionality. I already have a screen so just need the internal hardware. There seem to be a lot of options, I’m looking to see if someone would do the installation and supply for a fee. I live in the Bath/Bristol area
- markplant
CarPlay Retrofit
Anubiszed on here
https://youtube.com/@BMWZ4Mods?si=IApeL-VhHPMJf9ls
But he's in Lincolnshire
But certainly seems to have tried the options
CarPlay Retrofit
Thanks Mark
Smallsy99, as mentioned I'm in Grantham Lincolnshire, I do offer a fitting service for these, but I also have videos on how to fit them and always plenty of free advice.
My personal recommendation is the Mr12volt mmi box, I think it's the best on the market. It has a better integration with the OE look and the sound output is a digital signal via the MOST fibre optic network as opposed to using the analogue AUX socket like all the others do.
Check out my video here...
https://youtu.be/EY4XAzUYiXk?si=OTq4hRwnpHIdqMxL
There is a direct link in the video description.
Bath/Bristol isn't far if you fancy a drive I've had owners from as far as Scotland, France and Belgium in the past
Dave
2011, 23i, Grey with Red leather.
- Reamesy
CarPlay Retrofit
I can second the above recommendation for Mr12volt. I’ve been using this for two months and it’s slick with superb sound quality. Best upgrade yet
Currently; 2011 E89 23i SDrive M Sport Highline Titan Silver
Previously;
2014 SLK250CDI AMG Sport
2012 E89 SDrive 2.0 M Sport. White
2011 Audi TT Quattro
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
CarPlay Retrofit
One question I have about the Mr12Volt mmi - is there a recommended rear view camera to use with it ?
CarPlay Retrofit
Dave
CarPlay Retrofit
AnubisZed did my Mr12Volt installation and I can't recommend him enough. Good quick installation.
As for the unit itself, it totally changes the entertainment experience.
CarPlay Retrofit
I followed Dave’s video and fitted the mmi box (aux) before new most was available.
Video is really clear and helps you through all the steps
Also fitted rear camera in a number plate mount and front in grill ( front is not really that useful )
Fairly easy if you like to do it yourself and works really well
- nick_l
CarPlay Retrofit
Which camera did you install in the rear? I have the most box fitted and want to put a rear camera in.birdy_z4 wrote: ↑Sun Feb 25, 2024 12:57 pm I followed Dave’s video and fitted the mmi box (aux) before new most was available.
CarPlay Retrofit
This is the one I've currently got...nick_l wrote: ↑Sun Feb 25, 2024 6:04 pmWhich camera did you install in the rear? I have the most box fitted and want to put a rear camera in.birdy_z4 wrote: ↑Sun Feb 25, 2024 12:57 pm I followed Dave’s video and fitted the mmi box (aux) before new most was available.
https://amzn.eu/d/dKgGOyK
Dave
CarPlay Retrofit
I’d love to put one of these cameras in but I have no idea what type/brand of MMI box I have. No idea how to deduce / which connective wires I need…!
2010 E89 35i — turbo boat hooligan - viewtopic.php?t=131886
2008 Ducati 1098S — two wheeled nightmare
CarPlay Retrofit
This is the one I installed
Just found this amazing item on AliExpress. Check it out! £6.75 | SINOVCLE Car Rear View Camera EU European License Plate Frame Waterproof Night Vision Reverse Backup Camera 4 Or 8 LED light
https://a.aliexpress.com/_EygSRrB
CarPlay Retrofit
It doesn't matter which mmi you have. They all have a yellow RCA plug for the camera feed and a red trigger, Firstly forget the trigger as we don't need it.
So install the camera and run the wires into the boot area. For the camera feed (yellow) run this to the front of the car and to the mmi. For the power, run the black and red wires to one of these
https://amzn.eu/d/e38Yoh1
Then the black from this box to ground and the red to the reverse wire of the rear light cluster. This filter box cleans and smooths the reverse wire signal to give a steady, non flickering, video image.
Dave
CarPlay Retrofit
Tremendous stuff there Dave (as always) - onto the shopping list it goes
CarPlay Retrofit
How much would you charge to set this up and roughly how long would it take @anubiszed thanks
