This isn't a problem per se.. when I replaced a sticking caliper, I installed it onto the existing brake hose. This worked fine, but was a bit of a job as the connections were fairly well corroded at both ends.
Front driver side replaced, but front left side is on my list as preventative. At the same time, I ordered a new pair of hoses as they were fairly inexpensive.. the thought being a full brake fluid flush and replacing both hoses would be worth while.
The fit seems a little odd though? See attached... doesn't seem to screw the whole way in?
Caliper and Brake Hose Fit?
- PXL_20240122_104508638.jpg (324.23 KiB) Viewed 168 times
- colb
AS long as there are no leaks it should be fine, replace mine on a Morgan with stainless hoses years ago and they fitted same as your picture, never had an issue with them.
Z Shed Cymru member
1999 1.8 Z3
2003 2.5 Z4
1999 1.8 Z3
2003 2.5 Z4
- axelleveau
I don't have a picture on hand but from memory my new calipers and braided hoses fitted in the same way
Gone - Ford Ka MK2 Petrol - Black
Will hang around to carry materials/people and in emergency - Ford Fiesta MK7 1.0 Ecoboost - Black, white rally rims, white decals, remapped
Now - Z4 Coupe - Montego Blue: Here
