E89 door lock
E89 door lock
hi , has anyone experienced problems with door not opening ? i have 2010 z4 ,during this cold spell the drivers door wont open, it unlocks but wont open , never had an issue until cold weather. the door lever lifts but wont release, had to climb in passenger door, still wont open from inside. However once car warmed up the door opened fine. Question, will cold weather affect the lock actuater ? expensive part to replace ,want to be sure thats the problem. Grateful for any information or advice, many thanks Dialy
OnlineB21
E89 door lock
Quite common ..if there’s a bit of moisture things stick..bit of silicone on rubber and maybe a bit of WD40 in the lock..
E89 door lock
thanks B21, but tried all those, its definatley not sticking door seals and have drenched with wd in every orifice with no joy. Actuater is likely problem , various prices online from £30 - £110 !!!
- Reamesy
E89 door lock
If it’s the actuator will this not show with a diagnostic?
Currently; 2011 E89 23i SDrive M Sport Highline Titan Silver
Previously;
2014 SLK250CDI AMG Sport
2012 E89 SDrive 2.0 M Sport. White
2011 Audi TT Quattro
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
E89 door lock
Hi Ramsey, not had it on diagnostic, problem only happens when very cold weather
E89 door lock
Have same issue with my 64 plate E89 every winter when it freezes . Windows dont drop even when door handle is pulled up. Door wont open despite having used gummi phledge on door seals several times. I use an old credit card pushed between window and seal and work round. Also push card between top of door panel and bottom window seal. Eventually window usually drops down and I can then slowly open door hopefully without damaging door seal.
E89 door lock
Unfortunately - if you force it open (even 'gently') you are very very likely to be causing damage to the seal.
Same circumstances next time it freezes hard will ge gradually worse (best case) or properly wrecked seals if you are clumsy.
No way to force open a frozen door without doing something bad - even if it's just a tiny bit.
- enuff_zed
E89 door lock
Are you sure? 99/100 its the door seal sticking.
If it was only one door then it is possible the other door was sheltered more (or the sun had already got to it before you arrived).
Try parking the car the other way round and see what happens.
E89 door lock
i had this last week when frosty. The passenger door would not open as the window would not drop, I was able to get in the drivers side and switch on the heating. Once the passenger side defrosted a bit it opened fine.
E89 door lock
Definitely not frozen door seal ,wish it was.
I can feel door moving if I press against it, as when I do get the door open it won't close properly,not latching and window doesn't rise unless I press against the door but still doesn't latch. Have driven it holding door closed until it warms up,then fine til the next time . Did have a word with auto trician, he reckons tired actuater.
Online
E89 door lock
Odd!Dialy wrote: ↑Fri Jan 19, 2024 3:06 pm Definitely not frozen door seal ,wish it was.
Have you checked that both the door internal mechanism and striker plate bolts are all tight? If just one was a little loose, it would make something shift, possibly enough to give this problem. It's worth checking.
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
E89 door lock
Many thanks everyone for your comments, advice etc, tried opening this morning ( I did.cover it up last night ) and hey ho it opened no problem !! Now what ?
- Reamesy
E89 door lock
Maybe take a look inside the door to see if water is coating the actuator mechanism and freezing. Lube it up with oil and see how you get on. Worth a try to avoid replacing parts
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
Previously;
2006 Z4 2.5 Sport
2013 420D coupe
2002 Z3 2.2 Sport
1996 Z3 1.9
