2 or 4 Post lift.
- pvr
2 or 4 Post lift.
I thought that when I got the plate "VR" for it, that it was my initials - not knowing it stood for "Very Rusty"
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- pvr
2 or 4 Post lift.
Are your Tetanus injections up to date?
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- enuff_zed
2 or 4 Post lift.
Can't understand it tbh.
My wife is from Scotland, but she's not rusty underneath.
Perhaps she was summer use only.
2 or 4 Post lift.
Had a few delays and even more mind changes but no going back now. Automotech 4 post lift arrived today, fingers crossed, should fit it over the weekend. Well start it at least.
- IMG_20240215_101415.jpg (156.39 KiB) Viewed 288 times
Silver M Roadster
220d Active Tourer
Landrovers 90 & 110
220d Active Tourer
Landrovers 90 & 110
OnlineMr Tidy
2 or 4 Post lift.
Just out of curiosity but what prompted the change from 2 post to 4 post?
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- B21
2 or 4 Post lift.
Serious installation …
- pvr
2 or 4 Post lift.
Very impressive. Are you assembling it yourself?
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Online1536Z4
2 or 4 Post lift.
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
2 or 4 Post lift.
My brain not listening to the laws of physics. Not so much with the Z but the Hanging off a land rover on a wrecking bar worries wouldn't go away and mounting a 110 on the 2 post looked a bit tricky. I might even get a 2 post some time
Silver M Roadster
220d Active Tourer
Landrovers 90 & 110
220d Active Tourer
Landrovers 90 & 110
2 or 4 Post lift.
Mostly but some bits look a bit heavy and awkward, so my bezzy oppo Dave might have to come over for coffee. I always prefer to do things myself then I know it's done correctly, no corners cut and if it all goes pear shaped then it's no one else's fault.
Silver M Roadster
220d Active Tourer
Landrovers 90 & 110
220d Active Tourer
Landrovers 90 & 110
Online1536Z4
2 or 4 Post lift.
Thats alot of space . Wish my garage had the height to fit something like that .
2 or 4 Post lift.
I don’t think you’ll be disappointed with the quality and fit Nick…my two lifts went together with no issues.
One thing to mention, you’ll need a C rated circuit breaker of the correct amp as B rated either trip, or the lift won’t even try to fire due to the initial voltage surge needed.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
OnlineMr Tidy
2 or 4 Post lift.
I know what you mean - it doesn't look like it should work, but I've seen X5s on 2 post lifts at my BMW Indy.Nick W wrote: ↑Fri Feb 16, 2024 11:32 am Mr Tidy wrote: ↑Fri Feb 16, 2024 12:08 am
And the bonus of a 4 post is you'd be able to do 4 wheel alignment, although I imagine the laser kit from people like Hunter doesn't come cheap!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
2 or 4 Post lift.
Thumbs up for the quality, it's not too often I feel like I got my moneys worth. It weighs more than I expected. Got promoted to granddad duties most of the day but still managed to put the bits all in the right areas and the right ways up. Not had to use Dave yet but he's an electrician so he'll sort that side out. I only did the first fix and left the thinking bit to him but the fuse on the board is C rated and its all armoured cable with 25mm swa 100amp cable for the supply, looks like overkill but should do the trick and it was left over from another job so cost nowt. As for allignments i'm making a string frame to fit on the ramp, I'd have to sell the silver to buy a Hunter kit.
Silver M Roadster
220d Active Tourer
Landrovers 90 & 110
220d Active Tourer
Landrovers 90 & 110
OnlineMr Tidy
2 or 4 Post lift.
Don't blame you!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
