2 or 4 Post lift.
2 or 4 Post lift.
I've almost finished building my new garage after spending the last 22 years planning it and now can't make my mind up between a 2 or 4 post lift. I always wanted a 4 post but recently most of my mates insist a 2 post would be a better choice. I've never owned either and never paid much attention to the few that I've worked underneath, so this is where I would welcome any opinions /experiences /makes to look at or avoid etc. The concrete is minimum 6" deep C35 and it will have to support all from the Z to a 2 1/4 ton Landrover.
Silver M Roadster
220d Active Tourer
Landrovers 90 & 110
220d Active Tourer
Landrovers 90 & 110
- Mr Tidy
2 or 4 Post lift.
I've never had access to either but I would have thought a 2 post lift would give much more access to the underside of the car, and make it much easier to take wheels off to sort out brakes or suspension.
AFAIK the only drawback is you need a 4 post to do laser wheel alignment as the car needs to be sitting on its wheels.
Hopefully someone who has used one or both will be able to help.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Ed Doe
2 or 4 Post lift.
I'm quite tempted by a lift giant 4poster, because they don't need to be fixed to the floor, and when they don't have anything on them you can move them about on caster wheels...
https://liftgiant.co.uk/parking-lifts/f ... king-lift/
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, Supersprint, RTD, 4.1FD
Silver Grey '06 3.0si Coupe - SOLD
- B21
2 or 4 Post lift.
Good news on the garage…I assume it’s of generous proportions as both the 2 and 4 post lifts take a lot of space?
How’s your head room?
2 or 4 Post lift.
I'm lucky, it's 10m x 10m x 5m high, so either will fit and leave plenty of room for all of my junk. When it's all done I'll put some pics on the Man Cave thread. I might just flip a coin
Silver M Roadster
220d Active Tourer
Landrovers 90 & 110
220d Active Tourer
Landrovers 90 & 110
2 or 4 Post lift.
I have a scissor lift which is very similar to a 4 post Nick in that it carries a vehicle on its wheels or not if you have jacks, and a 2 post lift, and if I had to get rid of one of them it’d be the scissor no question. Don’t flip a coin, they’re very different beasts.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
2 or 4 Post lift.
The 2 post gives so much more room to work on a vehicle, has very few downsides, and if height isn’t an issue you can get one with the crossmember above the vehicle so there no trip hazards. As Mr Tidy quite rightly says the only reason a 4 poster is superior to a 2 post is keeping the wheels on for alignment etc.
Automotech in the midlands have a wide range of lifts, are very well made and ultra competitive on price.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
2 or 4 Post lift.
They look good and must be safe but my brain couldn't handle it not being bolted down. The main reason I'm wary about the 2 poster is I'm worried it might fall over if I really hang off a spanner. Stupid I know but hard to un-think.Ed Doe wrote: ↑Thu Jan 11, 2024 10:52 pm I'm quite tempted by a lift giant 4poster, because they don't need to be fixed to the floor, and when they don't have anything on them you can move them about on caster wheels...
Silver M Roadster
220d Active Tourer
Landrovers 90 & 110
220d Active Tourer
Landrovers 90 & 110
2 or 4 Post lift.
So much room to work in a car, no ramps each side to hinder movement and access.
- IMG_0144.jpeg (177.74 KiB) Viewed 564 times
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
2 or 4 Post lift.
12 M24 through bots hold it down, and unless you’re a complete numpty positioning the car it won’t fall off the arms even if you hang off the bumpers.Nick W wrote: ↑Fri Jan 12, 2024 12:02 amThey look good and must be safe but my brain couldn't handle it not being bolted down. The main reason I'm wary about the 2 poster is I'm worried it might fall over if I really hang off a spanner. Stupid I know but hard to un-think.Ed Doe wrote: ↑Thu Jan 11, 2024 10:52 pm I'm quite tempted by a lift giant 4poster, because they don't need to be fixed to the floor, and when they don't have anything on them you can move them about on caster wheels...
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
2 or 4 Post lift.
Thanks John, that's reassuring and your setup looks perfect, now I'm really buzzin.john-e89 wrote: ↑Fri Jan 12, 2024 12:08 am12 M24 through bots hold it down, and unless you’re a complete numpty positioning the car it won’t fall off the arms even if you hang off the bumpers.Nick W wrote: ↑Fri Jan 12, 2024 12:02 amThey look good and must be safe but my brain couldn't handle it not being bolted down. The main reason I'm wary about the 2 poster is I'm worried it might fall over if I really hang off a spanner. Stupid I know but hard to un-think.Ed Doe wrote: ↑Thu Jan 11, 2024 10:52 pm I'm quite tempted by a lift giant 4poster, because they don't need to be fixed to the floor, and when they don't have anything on them you can move them about on caster wheels...
Silver M Roadster
220d Active Tourer
Landrovers 90 & 110
220d Active Tourer
Landrovers 90 & 110
2 or 4 Post lift.
2 post lift will be fitted next Tuesday, 23rd. Thanks again.
Silver M Roadster
220d Active Tourer
Landrovers 90 & 110
220d Active Tourer
Landrovers 90 & 110
- pvr
2 or 4 Post lift.
Will be good to see a pic of that with a nice car on it, not some old Jap banger
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
2 or 4 Post lift.
Bollocks you…..
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- enuff_zed
2 or 4 Post lift.
Don't worry John. He's just jealous as if he had one he'd need a hard hat for all the rust dropping on him.
