Z4M - Best brake upgrades 2023
I’m in Surrey/ south west london. Would be good if you don’t mind depending if that’s near to you
2007 Z4M Coupe
- barryb97
PB Brakes
CDV del, clutch stp, LeatherZ console, strut bar, PB brakes, TC Kline coilovers, M3 reps, Stromung, Intravee II, paintd reflect, Hdlt wash disable, AS SSK, RTAB lmtrs, Vibra tech, BMW pedals, Skyer frnt. r lip, r defuser, coil cover, rad cover.
Thanks for all the suggestions
Now just need to make a decision
Anyone know how much extra a brake disc would need to be offset vs. E46 M3?
They shared brakes.
As above the brakes on both m cars were the same however the steering knuckle is different meaning that some brake options for the e46 m3 don’t work on our m cars the same. I’m unsure of exact differences as I can’t find any dimension drawings of the parts
2007 Z4M Coupe
I like the idea of trying to fit the f8x CCB but needs to be shimmed 3mm for E46 . . So would need more for Z4 - Expensive to try and find out if it’s possible!
I’ve got some second hand parts to fit to keep me going until I see a decent deal on an upgrade.
I’ll put it this way, I believe the Z4M need about 5-6mm shim to run the e92 m3 front discs while the e46 m3 can bolt them straight on so based off that logic you would need around 8-10mm of shims to work which is probably too much
2007 Z4M Coupe
Yeah think you are right - on the plus side that will save me a lot of money
- wspohn
I don't get this. There are many cars with substandard brakes that cry out for an upgrade and in those cases the need to refresh what is there is a good excuse for an upgrade, but the stock brakes on the Z4M are excellent and the only change that might be arguably worthwhile is a switch to a different pad compound to suit whatever use you are making of the car.
Given the various fiddles and machining operations needed to fit different calipers that may be of questionable virtue as far as actual performance improvement goes, I question whether the urge to modify just for the sake of it is sensible. Are you planning to track the car or are you just after bragging rights? Have you found the braking performance to fall short of what you wanted for street use?
Vancouver BC, Canada
2007 Z4MC
2009 Solstice GXP coupe
1962 MGA Coupe
1956 MGA (rebody+re-engined)
1958 MGA Twin Cam race car
1972 Jensen Interceptor
2007 Z4MC
1962 MGA Coupe
If I need to spend some money on replacing/fixing anything always look at the upgrade options vs. OEM, don’t get why you wouldn’t - it’s a 18 year old car, technology has moved on etc, so always worth a look.
Not had a problem with the standard brakes, however I think a BBK looks better, I’ve supercharged the car so any additional braking ability can’t hurt & main reason is I enjoy modifying cars
- 3gGT01
Thought I would source rears from Rockauto as remans, but after receiving 4 driver's side calipers instead of passenger side will just keep one of the the drivers side and sourcing used off of eBay. All this shipping time has really drawn out this whole upgrade!
- 422 passenger side I'm currently working on. Cut out on both ends for cross over tube.
- IMG_3625.jpeg (176.78 KiB) Viewed 331 times
- My cleaned up snobbed one
- IMG_3614.jpeg (144.42 KiB) Viewed 331 times
2007 Z4MC Interlagos Blue Metallic w/Light Sepang Bronze Nappa interior. 'Emma'
- Beedub
Here's a pic of my setup .... Again amazing brakes truly amazing but the replacement parts just seems way way way over priced.
- 20230904_180125.jpg (282.84 KiB) Viewed 267 times
- 3gGT01
That's a beast! Looks good though! Any proportioning valve additions/changes to make that 6 piston work?
- Beedub
its all properly piston sized for the master cylinder etc.... the 4pot rear can feel abit aggressive with a less sticky tyre but outside of that its absolutely unreal... Had these fronts glowing red a few times!
