Winter comes to the Scottish Borders..
Mass migration to all season and winter tyres for the dailies..the Zed is resting on refurbished 437M in graphite grey with new SC7s..unlikely to be out much over the winter but spring pot holes are a killer ..so forged wheels stand a better chance.
The Apex Arc 8s are off for trueness check and then refurbished in graphite grey with fresh SC7s..
A little left in the old SC7s..3.6mm in 10k old fronts and 2.7mm in 5k rears..but it’s not worth (to me) faffing for 1 or 2 runs.
Plus early spring weather can be wet and 3mm is about it for good water performance…and at 2mm had bad tramlining on the rears…
Please with general wear pattern…with revised geometry ..no uneven wear..
Feeling wheely good…
- B21
- IMG_8487.jpeg (321.87 KiB) Viewed 592 times
- IMG_8484.jpeg (204.45 KiB) Viewed 592 times
- IMG_8483.jpeg (156.93 KiB) Viewed 592 times
- IMG_8485.jpeg (185.62 KiB) Viewed 592 times
- IMG_8486.jpeg (311.37 KiB) Viewed 592 times
- IMG_8492.jpeg (215.76 KiB) Viewed 592 times
- IMG_8482.jpeg (170.83 KiB) Viewed 592 times
- MikeyH
You've surprised me that the back tyres can cause tramlining, do you think would this be the case on E85? Mine are down to 3mm.
- B21
Most tramlining is caused by rear tyre / wear / camber / toe settings…
Front related issues cause more of darting / twitching behaviour…
Sometimes you get both…nice
- sars
That's a lot of wheels
Gorgeous SFR Z4 M40i
Gone 2017 Iridium SL400, 2015 435d xDrive Convertible, 2012 E350 CDi Convertible, 2010 DSB Z4 sdrive30i, 2008 Audi A4 Cabriolet, 2006 Phoenix Yellow Z4 2.5Si, 2003 Saab 9-3 Convertible
- B21
I’ve cut back now I don’t use the Zed for winter duties.. so one less set..
- MikeyH
Very interesting
- N4LLY
16 wheels
Would it not be cheaper to but a winter workhorse "X3" ?
- buzyg
- B21
I have an XC70…still need winter tyres..ever seen the video of BMW X in snow on summer tyres ?
