Karbonius Race Airbox
"M" Specific discussion
///MBan
Post by ///MBan » Sat Dec 02, 2023 11:54 pm
GT Spec wrote: Sat Dec 02, 2023 5:35 pm
///MBan wrote: Sat Dec 02, 2023 2:20 am
///MC wrote: Tue Nov 28, 2023 5:53 pm Hey,
I also recently installed a Karbonius Race airbox. Mine does not have the cut on the snorkel ( production August 2023) , i also had to trim it a tiny bit but as you can see from the pic, I kept the rubber part feeding the air from the grills and it lines up perfectly to feed the airbox.
I did previously have an eventuri intake, while alot of people will say it sounds similar to an airbox, it really isnt close, the airbox fills up the cabin with induction roar all the way to 8000 rpm. I actually removed my RPI mufflers just to enjoy the glorious induction noise.
Did you use a Dremel like GT Spec to trim the throat? And how did you work out how much to trim off - trim a bit off at a time until it fit?
I have one of these boxes on order and have to admit to being nervous about cutting it!
Where are you based? If you are fairly local I can walk you through it when you are ready to install it. Are you aware you need the earlier style rubber throttle boots? The later engines such as the ones fitted to the E85/6 had different boots from build. Let me know if you need part numbers etc.
Thanks for the offer, but I'm in Perth, Western Australia.
Thanks for the tip on the rubber boots - I actually bought a set of the Karbonius OE-style plenum I have, so I'm sorted there. I've also ordered the rest of the parts from Schmiedmann as well as the IAT harness from Turner, so I think I'm set!
However, always good for a cross-check, so this is my list of parts:
Part Qty P/N
CSL IAT Sensor 1 13629899008
IAT sensor o-ring 1 13621743299
CSL Crank Case Vent Hose 1 11157833649
CSL Airbox Air Shut Off Valve 1 11617833647
Alpha-N IAT Harness 1 Turner
rubber intake mounts 2 11617830735
Hose clamp - plenum side 6 11617830306
Hose clamp - throttle side 63mm 6 11617831745
Rubber intake boots 6 11612466477
CSL OE filter 1 13727838625
Justino
Post by Justino » Sat Dec 02, 2023 11:59 pm
Hi GT Spec
the part number for the rubber boots would be helpful if you can provide so I can scope those out.
Hi ///MC
On the Hack Engineering website pictures of the Karbonious there is a bottom feed connection also - has this been deleted now? I cant see it on the Karbonious website? I was going to get the piping and connect that up for extra air.https://www.hackengineering.co.uk/produ ... ox-e46-m3/
I've also seen pictures with a section of the inlet cut-out - where it would be close to the grille inlet - is that no longer the case also? Can be seen here, and also the bottom feed pipe again. Do you think the side cut-out would be beneficial for the air entry given the grille intake on a Z4m? https://www.apmotorsport.co.uk/product- ... us-v2-race
2008 Z4MR Silver Grey
2017 Audi A6 Avant Quattro 3.0 BiTdi
2003 Clio 172 Cup
Justino
Post by Justino » Sun Dec 03, 2023 12:10 am
This shows the bottom inlet pipe, and cutout
2003 Clio 172 Cup
///MC
Post by ///MC » Mon Dec 04, 2023 7:01 am
GT Spec, Mine is exactly like the pic
///MC
Post by ///MC » Mon Dec 04, 2023 7:05 am
Justino, This is the old design as you can tell by the plastic trumpets. Now its all CF and the snorkel no longer have the cut and attachement opening. My air box is produced August 2023 and it is like the picture I posted above.
///MBan
Post by ///MBan » Tue Dec 05, 2023 12:11 am
Justino wrote: Sat Dec 02, 2023 11:59 pm Hi GT Spec
I put them in my part list above:
Justino
Post by Justino » Mon Dec 11, 2023 12:24 pm
Thanks, missed that - not cheap I see at £30+ each.
///MBan wrote: Tue Dec 05, 2023 12:11 am
2003 Clio 172 Cup
///MBan
Post by ///MBan » Fri Dec 15, 2023 5:36 am
Agreed! Turner does a kit with silicone boots and jubilee clips that is much cheaper and makes it easier to change in the future. But, of course, it looks aftermarket.
Justino wrote: Mon Dec 11, 2023 12:24 pm Thanks, missed that - not cheap I see at £30+ each.
GT Spec
Post by GT Spec » Sat Dec 16, 2023 2:01 pm
///MBan wrote: Fri Dec 15, 2023 5:36 am Agreed! Turner does a kit with silicone boots and jubilee clips that is much cheaper and makes it easier to change in the future. But, of course, it looks aftermarket.
I bought the Samco kit in classic look black as I wanted to keep the original look but had to return them as they really poor quality. Stick to OEM!
E85 M, Aero Skirts and Hardtop
Schrick 288/280 Cams and Rockers
BMW Motorsport 4.1 FD
Supersprint Full System inc 100 Cell Cats
163M CSL Rims
Bilstein/Eibach B12
Recaro Sportster CS
Diagnostic scanning and coding in Essex
Justino
Post by Justino » Thu Jan 25, 2024 4:02 pm
Finally done it - placed the order yesterday, circa 8 week lead time!
Any recommendations for the Alpha N remap - I am based in the Midlands?
I am assuming it will be ok to drive to the mappers after the intake is fitted as it will default to a 'stock' map in the absence of the MAF data?
2003 Clio 172 Cup
GT Spec
Post by GT Spec » Fri Jan 26, 2024 12:13 am
Justino wrote: Thu Jan 25, 2024 4:02 pm Finally done it - placed the order yesterday, circa 8 week lead time!
100% contact Josh at Severn Tuning. He is based in the US but will map the car remotely using data logs and a final dyno session.
163M CSL Rims
Bilstein/Eibach B12
Recaro Sportster CS
Justino
Post by Justino » Fri Feb 02, 2024 5:52 pm
GT Spec wrote: Fri Jan 26, 2024 12:13 am
Ideally prefer a one stop shop, ie have their own rolling road and map accordingly. Means I can get it done all in one day.
2003 Clio 172 Cup
SGRG
Post by SGRG » Fri Feb 02, 2024 7:10 pm
Justino wrote: Fri Feb 02, 2024 5:52 pm
Recommend these guys for one stop shop: https://areevemotorsport.uk/
https://www.instagram.com/tv/CmZm6-FKjz ... hoMXplejJl
Current:
Z4MC 2007
Porsche Cayenne 2019 (Black / Bordeaux Red two-tone leather interior)
Previous:
X5 40D 2011
E92 M3 manual 2011
Z4 3.0 2003
Honda Prelude 2.2 1997
Honda Civic Coupe 1995
Jon2215
Post by Jon2215 » Fri Feb 02, 2024 11:21 pm
SGRG wrote: Fri Feb 02, 2024 7:10 pm
+1 for Arreve.
2007 M Coupe
Interlagos Blue,Sepang leather,carbon leather trim
RedUn
Post by RedUn » Mon Apr 08, 2024 8:42 pm
Just in the process of stripping plenum for Karbonius and thought I'd share a tip, bicycle chain pliers such as the ones below are perfect the OEM clips on the rubbers :thumbsup:
IMOLA Z4///MR
