SOLD BMW Z4M Roadster £10k -11 Services, Modified (BC's, Valved Exhaust)
- Snakobs
Interlagos blue BMW Z4M roadster
Currently on 94,000 miles and is in use daily so will rise, selling as need a 4 seater.
Next MOT due 05/09/24
Service History:
0000 miles -Pre Delivery Check
1140 miles - Running in Service
10,678 Inspection 2 service
22,974 Inspection 1 service
46,848 Inspection 2 Service
60,626 Inspection 2 Service
73,528 Inspection 2 service
77,698 Inspection 1 service
77,789 Inspection 1 service
80,407 Inspection 2 service
86,621 Inspection 1 service
94,000 Current Mileage
Maintenance /Upgrades:
BC RM coilovers fitted Feb 2023, lowered 25mm front, 20mm rear. 32 way rebound adjustment.
Hardrace lower control arms, new Lemforder tie rod and tie rod ends.
Forge Motorsport wheel spacers, 15mm front, 12mm rear. Bimmec extended wheel bolts.
Alignment set-up using string theory, approx 2 degrees camber on rear and 1.25 degrees front.
Custom 3" valved cat back exhaust, V-Band quick release, profusion parts, wired F30 M3 butterfly valve.
Short shifter install mounted on transmission tunnel to eliminate shifter play.
Roof motor relocation to boot, faux carpet trimmed
Venoxy custom yellow M guages
4 new matching tyres May 2023
Yellow painted V Bars behind the grill
Hack Engineering Clutch Delay Valve Braided Line
3D Printed Clutch Stop to remove deadzone travel
OEM BMW wind deflector fitted
M-Tec Dynamics yellow seatbelts
Front plate surround drilled and flushed
KBR E46 fire extinguisher bracket & Safelincs fire extinguisher
Bluetooth handsfree adapter wired in to allow handsfree audio
Brembo front and rear pads fitted, including pagid handbrake shoes
Features:
Electric M-Sport heated seats, memory seats, auto air conditioning, navigation system professional & telematics, onboard maps, original phone cradle, bluetooth handsfree, multi function M steering wheel, Xenon headlights, 6 CD changer, cruise control, electric folding & Auto dimming exterior mirrors, auto dimming interior mirror, OEM wind deflector with boot storage,
Please Note:
224M wheels need a refurb due to corrosion.
Front bumper needs a re-spray.
Diff bush needs changing as split, knock can be felt going into gear.
Cup holders arms snapped.
Only 1 key.
Private plate will come off before sale.
Priced at £10,000 given condition. If no sale, goes part ex. Located Cheltenham /Bristol.
Thanks, Matt
Service History:
Features:
Please Note:
Only 1 key.
Thanks, Matt
- IMG_2950.JPG (190.16 KiB) Viewed 1745 times
- Snakobs
BMW Z4M Roadster -11 Services, Modified (BC's, Valved Exhaust)
No interest from the forums, link now live on Autotrader:
https://www.autotrader.co.uk/car-detail ... lq&fromsra
- Snakobs
Hi All, have I over priced this or am I just being impatient? Any tips to help get it sold?
I am having little interest in it and I would like to move it on for an X5 before peak summer.
Thanks in advance
Thanks in advance
The only way to achieve a quick sale is to drop the price, unfortunately. Getting a second key and the diff bushes sorted would help as well although you might not recoup the costs of doing that.
Nothing is selling, the M market is totally flat, there are cars that have been for sale all last year and still sitting there, day in day out the same cars are available on all the sites. I don’t know when or if it’s going to improve, not sure it will tbh.
Your car is well into the 90k miles without the rod bearings being at least inspected, which imho they’re due a look at at that mileqge, one key, some upgrades that are tasty but not necessarily appealing to a lot of potential buyers. It’s just imho but I think given how difficult it is to sell these cars at the moment, you’re into sub £10k to even get a sniff. I’m not meaning to offend but as you asked given the current situation….
Anyhoo I wish you well, but honestly I think you’ll be trading it in come summer.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- Snakobs
Thanks John, I appreciate the feedback. It's good to get a second opinion on it.
I will look to drop it to £10k given the market and update the ads.
Matt
Matt
- tomscott
Thats a cheap car for someone! GLWTS
- AndyBeech
As John has said more or less. As with any mods, beauty is always in the eye of the beholder, but the gear stick and huge fire extinguisher I don't think are doing it any favours for the regular punter. Probably easily enough removed but first impressions count and there's enough choice out there to be fairly fussy.
I would return it to a bit more standard if it was me.
Z4MR - Gruppe M, Bilstein PSS10, CSL's + 18" CSL reps with semi's, RTAB Limiters, Powerflex’d, PF Camber Arms, K-Sport BBK / RSL-29, GC Camber Plates, Strut Brace, Exhaust valves, custom brake cooling, complete underside refresh!
- Ed Doe
Looks like I've been beaten to it a bit(!)
It might not be what you want to do, but if you can, I'd recommend going back to standard with the exhaust, suspension & Shifter, and removing the fire extinguisher.
In my experience the mods you've done will significantly narrow your prospective audience, and you shouldn't have any problems selling the upgraded parts separately (the exhaust & suspension fits Roadster & Coupes, so wider audience, and the suspension I think possibly would fit an E36, the shifter is almost certainly universal BMW, so much wider audience....).
Up to you, but if you put even the shifter and exhaust back to standard, the 'look' of the car would likely appeal to many more people.
Just a thought, GLWTS either way chap
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, H&S, RTD, 4.1FD
Silver Grey '06 3.0si Coupe - SOLD
A kick in the teeth Matt for sure but hopefully you’ll get some interest with the revised price.
Seems that folk selling aren't willing to be realistic, which is understandable given what they, and I, will and have paid for these cars in better times, but unless they want rid they’re going to simply have to take a hit, or have them sitting for sale for who knows how long,..? I paid £18k for mine 7yrs ago, fully specced on 32k miles, it’s on 39k miles now waiting for a full on show car rebuild underneath when I can get to it, even when it’s done and hopefully looking factory fresh I reckon I’ll be looking at £14k-£16k ish tops…. Sad but the ground has dropped out from underneath these cars.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
- Snakobs
I will remove some mods but I sold a lot of the original parts on, so the BC's etc are going to have to go with the car
Cars are depreciating assets, I have considered investing more to bring it up to 100% but with the market as it is, decided not to invest anymore as I can't increase the advert price once it is out in the wild. So I will keep it at £10k and see if it drums up any interest.
We Buy Any Car are offering £5k so there's always financial suicide I am not forced to sell I have another car, so I can wait for a reasonable offer somewhere close to asking
- tomscott
I think it’s uncertainty of the market at the mo. WBAC offered me the same. Just silly really might as well break it for that money. Might be worth hanging on taking it down and selling come late spring when there is more demand
If I didn’t have the Alpina I’d be interested enough to view it.
Looks like it falls into the £395 tax bracket from the Autotrader listing, that’s a big plus point for a Z4M.
It’s a great colour
It’s decent Spec
Most mods easily reversible
Front bumper not an especially expensive job
Presumably HPI clear?
For me, the gear stick screams Tokyo-drift’ and abused, removing that and the fire extinguisher and putting the standard black seatbelts back in would help your cause loads… as would putting the standard dials back in.
Just trying to be helpful and looking at the positives… worth more than £5k in parts. Have WBAC actually appraised it/seen it in the metal?
It’s a great colour
It’s decent Spec
Previous Z4’s :E89 30i, E89 20i, E85 3.0Si (X4) E85 3.0i, E86 3.0 Si, E85 2.5si, E85 2.5i
- thecremeegg
I'm interested, I just need to sell my car first! I'll be trying to get it up for sale in the coming weeks so if anyone's after a 2003 3.0i with 150k miles let me know!
I would want the standard gear stick and the fire extinguisher removed as others have said. Have you still got the stock exhaust?
Z4M - Interlagos Blue with Black Leather
Z4 3.0i - Sapphire Black with Red Leather - FOR SALE!
- Snakobs
I have removed the fire extinguisher over lunch, so that's done. I have the original M knob in the garage but..
The shifter isn't an easy job, I would need to drop the exhaust and fit the original linkage back from the underside of the car, as this uses it's own linkage and bushings. I would rather sell it fitted unless it is an absolute deal breaker.
I don't haver the original exhaust, it is in a shed in Ireland if you want to go collect it
Matt
Matt
