What updates/repairs/mods have you planned for the winter?
- B21
I've decided to SORN the car and start early on with various items that were delayed, things that need fettling etc
What are your plans?
Here's a partial list
Repair / update / service
Oil and filter change
DCT gearbox sump repair and refill
Glue some areas of carbon fibre trim that have not stuck well between trim and various units like the heater controls
Check Apex Arc-*s for true and then repaint in graphite gray
Fit new 235/35 19 and 275/30 19 Conti Sports &
Lanoguard the underneath
Update s/w on MMI box
Replace disc in CIC unit with a SSD to avoid random rebooting
Upgrade
Fit IDMotion Instrument cluster https://id4motion.shop/products/digital ... 5980489879
Fit reverse and front cameras to that / MMI box
Fit blind spot warning system to new ID4 cluster
Fit Audiotec Fischer rear subwoofers
Fit Autdiotec Fischer Match 10 DSP amp
Fit uprated EKP low pressure fuel pump controller
Fit M3 dual mass flywheel
Upgrade
- IMG_2133.jpeg (141.47 KiB) Viewed 651 times
- IMG_2131.jpeg (155.08 KiB) Viewed 652 times
- id4motion-digital-cluster-theme-apex-thrill-fierce-oxide-03_5000x.jpg (67.2 KiB) Viewed 654 times
Having just bought the Z4 i am not planning much, just some small tweaks.
- Mr12Volt MMI box installation
- white LED bulbs for angel eyes
- white LED interior bulbs
- B21
Ah yes..all worthy items..if you get stuck I have another 100+ ideas for you!
yeah i would love to do the speakers, amp and i love the look of your Instrument cluster. But these will have to wait.
- Zed Baron
Peter be interested to see how you get on with the Lanoguard, just had the car serviced and now I've SORN'd it. Got to replace the headlight adjuster thing and then back into the garage until spring. Still in negotiations regarding its sale...
- B21
Wilco…
- Owdgit
All being well, I plan on an Oil & filter change service, replace brake pads and paint calipers, discs are fine ACF50 underside.
Any other jobs that 'pop up'.
I like to think I'm an optimist.
2010 Grey Z4 E89 N52 3.0 with stuff
2018 VW Arteon 2.0tsi daily workhorse
2020 KTM 1290 Superduke GT
- pvr
Starter motor, replace fogs, de-rust underneath, paint callipers, fit the subs, oil change and if brave, do an MOT.
Everything bought to do the jobs (except starter as is out of stock everywhere)
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- B21
ACF50?
May I ask why that amongst many others?
- Marcoose
The adjustable camber plates are making a clicking noise. They’ll be replaced with fixed -2.5° angle. And scheduled oil change, etc. All in early December.
2016 35is, monoballs, camber plates, KWV3, PS4S, xHP, MHD, LFB pedal, flat bottom wheel, red indicators, black headlamps
- B21
That's a lot of camber for the front...
- B21
What are you using for the de-rust /protection?
- Owdgit
Because I use it on my bike and bought 5 litres, always brings it up nice
- B21
Well that's one set of logic..
- pvr
POR-15, john-e89 recommended it so got a full set of de ruster and protection stuff. Also got the calliper paint from that.
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
