bad CSB symptome
arny14
bad CSB symptome
Post by arny14 » Tue Oct 17, 2023 12:43 pm
Hy,
Does anyone had worn central support bearing?(not the rubber) What was the symptoms? Is it common?
Thank you in advance
smorris_12
bad CSB symptome
Post by smorris_12 » Tue Oct 17, 2023 2:42 pm
It'll run rough and make noises like any other failing bearing. IME the rubber goes long before the bearing does.
Scott
Where are we going and why am I in this handbasket?
2006 Z4 2.5si Silbergrau und rot
arny14
bad CSB symptome
Post by arny14 » Thu Mar 21, 2024 2:59 pm
I changed it, didnt solve the issue.
j3nks79
bad CSB symptome
Post by j3nks79 » Thu Mar 21, 2024 3:53 pm
What issue are you having?
2009 09 Carbon Black Cinnamon E86
arny14
bad CSB symptome
Post by arny14 » Fri Mar 22, 2024 12:14 pm
You can hear the noise 0:25-0:30 and 0:35-40 for example. (diff changed, the wheel does not rattle when moved)
https://www.youtube.com/watch?v=_GPyuxuyJRw
