Already gone through the linerMrPT wrote: βFri Oct 13, 2023 12:15 pm I've run 245/35 fronts for a few years at stock-ish suspension height and camber. Marginal, at best, I reckon. You'll probably always have some kind of rub, but it might be worth it (especially if the rubbing settles down without going through the liners fully).
245/35 & 265/35 is a really sweet setup in terms of ride/handling, for example, and has that Porsche RS fitment look about it. Going from that to a 30 profile on the rear is a noticeable step down in comfort.
Tyre rub
Tyre rub
- patriot66
Tyre rub
On the outer edge of the liner where the wing/bumper joins ?stvh wrote: βFri Oct 13, 2023 12:25 pmAlready gone through the linerMrPT wrote: βFri Oct 13, 2023 12:15 pm I've run 245/35 fronts for a few years at stock-ish suspension height and camber. Marginal, at best, I reckon. You'll probably always have some kind of rub, but it might be worth it (especially if the rubbing settles down without going through the liners fully).
Tyre rub
Yes just behind the side reflector on the bumper.patriot66 wrote: βSat Oct 14, 2023 10:59 amOn the outer edge of the liner where the wing/bumper joins ?stvh wrote: βFri Oct 13, 2023 12:25 pmAlready gone through the linerMrPT wrote: βFri Oct 13, 2023 12:15 pm I've run 245/35 fronts for a few years at stock-ish suspension height and camber. Marginal, at best, I reckon. You'll probably always have some kind of rub, but it might be worth it (especially if the rubbing settles down without going through the liners fully).
- patriot66
Tyre rub
That's the usual spot
