New member intro
New member intro
Hi All!
This past weekend I went and picked up what I thought was a well maintained E85 with a 3.0i and 6spd, however when I finally got it home I discovered a LOT of issues. All in all the trip home was a nightmare but my wife has convinced me to fix it up instead of selling it.
Now, I am not new to BMW or turning wrenches (I had an E46 328i that I did all of the work to, rebuilt the VANOS, cooling system, power steering, alt, etc... plus owned a small performance shop for years) however the previous owner of this car did a real number on it.
I guess that's all I have right now.
- jock156
New member intro
Welcome
- buzyg
- paddy wright
New member intro
Welcome along
OnlineMr Tidy
New member intro
Welcome to the forum, and good luck getting your Z4 back to good health.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- DMike
New member intro
Hi and welcome to the forum! As you have worked woth the e46, youl’ll find the e85 pleasant to work with, plenty of room in the engine bay. Hope you get alll sorted out. Nice top color, btw
2005 Z4 3.0i Sterling grey
OnlineMikeyH
New member intro
Welcome to the forum, lots of good advice on here.
New member intro
Thank you all for the welcome!
I just want my car to be back on the road SAFELY.
So far the issues seem to be manageable, though now that I am making a list Im not so sure.
The "MUST BE FIXED" list
I NEED to replace the headlight wiring harnesses. The guy destroyed them installing crappy halos. The low beams are not even wired in and it ONLY has high beams. But YAY the stupid CFL halo lights work.
I need to actually attach the front struts to the car. He removed the after market strut brace and did not put the nuts back on the struts, and then drove around like that, so the studs are broken off.
The brakes are spongy but there is still A LOT of pad life left. So that just needs bled or master cyl replaced, but it holds pressure so bleeding those first.
The brake light is on and I know there is a broken pad sensor wire on at least one corner.
ABS/TC lights are on. Hoping that is just a sensor.
Engine light is on, not sure what that is for yet as it is not road worthy for me to go get it checked (my OBD2 scanner is.. somewhere.)
Both roof motors are broken.
The wing mirrors do not move.
The rest is just cosmetic.
Need to replace the interior plastics behind the seat because, again, destroyed.
Dream Red leather is ruined, so that needs replaced (Was told by an upholstery shop that for the extent of the damage it would be cheaper to replace since the covers need to come off anyway)
Need to replace the god awful wood trim (looked great in my 328, but not in a roadster) because it is destroyed and the aluminum looks SO much better.
The radio has an 'infinity knob', spin it 1000 times and the volume might go up enough to hear it..
New member intro
WTF!!!…. I hope the car was very cheapDarkApollo wrote: ↑Tue Oct 10, 2023 3:10 pm I need to actually attach the front struts to the car. He removed the after market strut brace and did not put the nuts back on the struts, and then drove around like that, so the studs are broken off.
Previous Z4’s :E89 30i, E89 20i, E85 3.0Si (X4) E85 3.0i, E86 3.0 Si, E85 2.5si, E85 2.5i
New member intro
It was not.. Because I had him send me videos of everything I asked for so I could see the condition before taking a 5 hour train ride to come get it and everything looked good. I paid right in the middle of the KBB value. I knew the headlights were 'cobbled together' but I didnt see the harness being hacked up in the video and I just assumed that since it was regularly driven and recently inspected, the most basic of things were in working order, like headlights and the freaking suspension.
At some point between the two weeks of him sending me the videos and me getting there.. He did this... If anyone is wondering, it is darn near impossible to find M8x1.25 press in studs. McMaster has thin panel studs, Dorman does not have them that small, and any place that I DO find them has a 4-6wk delivery time. Thankfully I have a metric ton of fasteners collected over a life time of "Well.. the car is back together but.. why do I have extra bolts" so that is the project for after work today..
Yep.. Seller thought this was totally safe to drive on. Even argued with me that he took it on a few hour road trip the day before I bought it to say good-bye and "It handled like it was on rails".
Note though, this was what it looked like after a few hours of my return drive when the steering wheel got really twitchy and it would cut in HARD. It started making a hard clunking sound on every bump so I pulled over to investigate. I imagine when I set off the drivers side still had two studs at least locating it in the tower. The wheels did not look out of camber when I bought it.
- DMike
New member intro
Right top shock mount cracked, strut tower eyelets for cross braces torn and rusty… Has he been doing stunt scenes with this car? What else could be messed with the front shocks?
- DMike
New member intro
…looking at your image, the right rear wheel starts to look suspiciously deep in the wheel well, too.
- N4LLY
New member intro
Jeeessh
Normaly i would say "Most excellent ! Congrat's" but
Good luck getting it straight
New member intro
Yeah the shock mounts will be replaced.
I ran the codes last night. Cyl 6 misfire, HO2 sensor, and coolent temp sensor. All things easy enough to fix.
Now that just leaves the traction control light which, knowing this kid beat the snot out of the car, could be anything.. Thankfully the ABS light is not on so I do not suspect the pump..... yet. I need to bleed the brakes so that could be part of the problem too.
Looking at different code scanners to read out the rest.. NT530 or a hacked version of ISTA
My current scanner is on a laptop anyway so lugging around a laptop isnt an issue.
OnlineMikeyH
New member intro
Wow, lots to do. Good job you know what you are doing, not sure whether or not it would be at the breakers had it been me.
