So relieved . I was getting quite anxious about recommending it and it all going t*ts up . Great to know that the support is decent . I`m really pleased you are enjoying the difference and thats on stage 1
Coupe modifications so far .............Latest update - Carbon Roof
- 1536Z4
Coupe modifications so far .............Latest update - Flyby sound videos of Simpson Race Exhaust
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
- bigwinn
Yeah I’ll get brave soon and go stage 2
Thank you great recommendation
Now off to put some sound deadening in the boot area
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- 1536Z4
If you do decide to go for it speak to Crest Automotive as they are the main importer and say they will beat any price https://www.catune.co.uk/single_prod-cH ... yOTkz.html
- 1536Z4
- 1536Z4
New Continental Sport Contact 7 tyres delivered today ready for spring .
- 20231206_172832.jpg (165.33 KiB) Viewed 559 times
- 1536Z4
Coupe modifications so far .............Latest update - Fitting Carbon Leather Trim
Finally got round to removing the aluminium trim and start fitting the carbon leather trim that I bought from forum member Wassup, and I am very happy with the way it looks . Now just got to remove the whole of the centre consol and everything else that goes with it to fit the last part . Not looking forward to that .
- 20231220_145830.jpg (161.64 KiB) Viewed 440 times
- 20231220_145815.jpg (170.92 KiB) Viewed 440 times
- 20231220_122425.jpg (179.55 KiB) Viewed 440 times
- 20231220_115316.jpg (164.31 KiB) Viewed 440 times
It’s not too difficult, really, you just need to do everything in the right order. Have you got instructions?
2003 Maldives Blue 3.0i auto
- 1536Z4
I`ve seen a couple of you tube videos and i`m sure I have seen the instructions on the forum somewhere . I will do a search unless you have them to hand ?
- 1536Z4
Thanks Zedebee . Lots of the guides on forums are now missing the photos or the links don`t work so this will help .
- 1536Z4
Coupe modifications so far .............Latest update - New Apex Wheels
Well that was fun . As I cant bend my left leg it makes things even more of a challenge as I cant kneel etc so I spent 2 hours in various positions some of which are probably not even in the Karma Sutra . Got there in the end though . I would say the most time consuming part was getting the knee pads off the console Eventually got a trim remover behind the front and slipped in another quickly behind it .
Once it was all out I realised I still had to cut the airbag button hole in the carbon trim as it only came with the sport button side done . Used a drill and then a deburring bit to cut the shape out but did not know that there is a thin wooden layer/ cork /veneer between the part and the leather . This caused the leather to lift as small bits of wood fell out from under the leather
I have glued it back down as best I can and will leave it overnight before possibly getting everything back together tomorrow. I am hoping it wont be too noticeable once the button is in and everything is back together . Not sure what I could have done any differently if I had known about the cork/veneer layer being in between .
- Barty
That’s annoying! You could add a minuscule film (so no drops!) of glue to the button. As I recall, it has an edge around the outside that would press down the leather once in place. Also, the button (and airbag light) clamp down fairly tightly when fitted
Four Alfa's and a Ducati later, I've turned to the dark side...
"Drive German, wear Italian, kiss French"
Z4: Tiefgrüen Metallic E86 3.0Si / Insta @bartsbuilds
- 1536Z4
I found a tube of fabric glue in a draw which said it was suitable for leather so have used a thin brush to apply it between the leather and cork veneer so hopefully that will work and as you say the button should hold it down .
- 1536Z4
Finished today apart from the handbrake gaitor as I am going to be adjusting that as its pulling up too much since having the cables replaced . Car now needs a hoover .
- 20231222_163438.jpg (164.86 KiB) Viewed 251 times
- 20231222_163352.jpg (157.42 KiB) Viewed 251 times
- 20231222_163337.jpg (139.93 KiB) Viewed 251 times
- Barty
Nice job, looks good! Don’t forget to put the handbrake into service mode when you do
