Hi,
Got a strange issue with my z4. Haven’t really driven it much the last year. Just re mot’d it because it’s ULEZ compliant. Weird thing is the roof doesn’t always active. Whether putting it down or up I press the button and nothing happens. I turn the car off and on again. Try with engine running engine not running. Suddenly it will just work. It has never not worked eventually but it’s obviously annoying.
Any ideas? Thanks
Roof doesn’t always work.
- bigwinn
possible that the roof control module is starting to fail or the loom is needing repair?
when it works does it work slowly and has the motor been relocated?
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
Motor was relocated by Bowser and then also had the pipes replaced. When it works seems to go normal speed
- enuff_zed
Had a similar issue. New module fixed it for me
Hi, I still haven’t tackled this yet. On another forum somebody said more likely to be be wiring than control module. If I try a new (second hand eBay) module will it work without being paired with my car? Also, are there any videos of how to actually do it as can’t find any. Or any instructions?
- enuff_zed
Simple plug and play. Behind the left seat there is a square grille on the trim. Pop this off and you can see the module. Small hands help but you can swap it through that hole.jackboy wrote: ↑Sun Feb 25, 2024 10:02 pm Hi, I still haven’t tackled this yet. On another forum somebody said more likely to be be wiring than control module. If I try a new (second hand eBay) module will it work without being paired with my car? Also, are there any videos of how to actually do it as can’t find any. Or any instructions?
