Started to install a BlueBus on my Z4 3.0si and have run into problems. It is connected and "working" but no audio plays through the speakers, only a faint hissing sound that gets louder as I turn it up. Radio works. My car did already have a CD changer, but I snagged the connectors from it and plugged it into the BlueBus. It does connect to my phone and all the functions of the BlueBus work, I can even play/pause from the steering wheel and everything.
Also when switching to the BlueBus mode it says "CDC 7" on the left side, and "TR01-001" replaces the main text for a second whenever a press anything, or go in the settings menu for example. (I recorded a video of this) So I'm not sure if the CD changer isn't fully disconnected and is conflicting with the BlueBus?
If anyone has any suggestions it'd help out, thanks.
BlueBus Setup Problems (Connected, no sound)
- photo_2023-09-16_18-29-33.jpg (190.56 KiB) Viewed 232 times
- photo_2023-09-17_15-38-25.jpg (191.67 KiB) Viewed 232 times
I would personally check if the CDC was working (just to rule out any wiring issues). If so, I'd send Ted an email. He usually tries to respond very quickly.
Exact same issue 100% the same. I’m assuming Ted saw this for you? Can you post what the issue and resolution was?
Thank you.
Thank you.
