Parking sensors
Parking sensors
Does anyone know how easy it is to add parking sensors? I was thinking about getting a different bumper with the correct holes, but i dont know what elsei would need. will the wiring all ready installed? etc
- pvr
Re: Parking sensors
I have just bought a sensor kit for a different car I just bought. Works with an antenna strip inside the bumper, so no holes.
Works off the reverse light, only 2 wires to connect.
http://www.rclick.co.uk/product_info.ph ... cts_id=698
Already bought / installed the keyless remote entry as well, and that did exactly what it said on the box so does not seem to be a bad company.
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Re: Parking sensors
Thanks for that. Is it any good?
- pvr
Re: Parking sensors
Will let you know once I have installed it, which should be in the next two weeks. For that money I thought it was worth a shot.
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Re: Parking sensors
yeah, let us know. If they any good then i will look at getting one too.
- Slapster
Re: Parking sensors
I will be interested to know as well - just been quoted £499 for front and rear "normals" fitted!!
2003 Z4 2.5i Roadster - Arctic Grey Metallic.
Regards from The Slapster, Cornwall, UK
Who hopes to die peacefully in his sleep, just like his Uncle.
And not screaming and shouting, like his Uncles passengers.
- peddy
Re: Parking sensors
pvr, so how did they turn out? how many sensors are there for the back? do you reckon it'll work for the front?
- pvr
Re: Parking sensors
It is a continuos sensor area across the entire inside of the bumper. The fitting is 2 connectors - one to earth, one to the power of the reverse light circuit.
For the front, it would work but you would have to manually switch the power on to get them activated though.
I have not fitted it inside the bumper yet, only tested the system as it is too cold to get the bumper off at the moment
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- cj10jeeper
Re: Parking sensors
pvr wrote:It is a continuos sensor area across the entire inside of the bumper. The fitting is 2 connectors - one to earth, one to the power of the reverse light circuit.
I reckon you could make a simple timer to control the fronts. Use the power from the reversing light to activate it and then leave it active for say 2 minutes.
That would be not unlike the other BM's where you engage reverse first to set the system. The only difference is they switch off at a certain speed rather than time.
Of course you could have a manual push button override so you could park in straight forward.
Re: Parking sensors
PVR any news?? Very interested in this if it works...
"If it doesn't put a smile on your face, it's time to do something else!"
- pvr
Re: Parking sensors
Have you seen the weather out there? Still on the to-do list ...
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- mikedav
Re: Parking sensors
I was bought this for Christmas one year for my Bora V6 4Motion. It's fiddly to fit; the 'sensor' is a strip of wafer thin alu foil you stick to the inside of the bumper. I could never get it to work consistently; sometimes it would beep like crazy four feet away, others 6 inches and in most cases, not at all. I threw it in the bin. I have heard of other people getting it to work ok though.pvr wrote:I have just bought a sensor kit for a different car I just bought. Works with an antenna strip inside the bumper, so no holes..
- srhutch
- Moderator
Re: Parking sensors
And you say I take my time, how long you had this lying around nowpvr wrote:Will let you know once I have installed it, which should be in the next two weeks. For that money I thought it was worth a shot.
- pvr
Re: Parking sensors
Touche ...
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Re: Parking sensors
I fitted the strip sensors front and rear last year to my Z4. Honestly, I found them to be less effective than the factory fit ultrasonic type.
False alarms more common, especially in the wet. You also have to be moving to trigger an alert which if you are about to mangle your bumper on a concrete post is a high risk reversing strategy.
Saying that, they do give some extra comfort provided you don't get blase about the false alerts. I prefer the discreet look as well. When reversing I still leave yards too much space, still cannot grasp concept I am sitting on top of reat wheels.
