Just wondering if anyone has installed E46 M3 front lower control arms?
If so, which modifications are required?
Fitting E46 M3 front lower control arms on E85/E86 Z4M?
What are you trying to achieve?
E85 M, Aero Skirts and Hardtop
Schrick 288/280 Cams and Rockers
Karbonius Race Airbox
BMW Motorsport 4.1 FD
Supersprint Full System inc 100 Cell Cats
163M CSL Rims
Bilstein/Eibach B12
Recaro Sportster CS
Diagnostic scanning and coding in Essex
163M CSL Rims
Bilstein/Eibach B12
Recaro Sportster CS
- hopz121
Better off with the Z4M version it has different caster settings to the E46 M3,
I believe the Z4M uses the M3 CSL offset caster lollipops.
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
The E46 M3 control arms have additional bolts which align with holes in the metal under-engine plate of the Z4.
That would provide additional stiffness to the whole front suspension.
There are 4 extra bolts used on the E46 m3, and the z4m shares the same engine under tray. The extra bolts go into the lollipop bushes and front control arm rear ball joint (the one that attaches to the front cross member).
You'll need to use the E46 m3 lollipop bushes (which are not Eccentric) as they are only compatible with the m3 control arms.
Not sure what geometry changes would ensue but it's definitely possible. Only one way to find out I guess
2008 Z4MR Ruby Black, Sepang Hell, Carbon Weave
2006 Z4 3.0si Montego Blue, Imola/Black individual
NCS/ISTA diagnostics & coding in Midlands - pm me
Thanks!
It looks like the M3 control arms provide more castor and effectively move the wheel forward.
I was hoping to find out from the experience of others... not my own
