I've recently bought a 2011 Z4 that has carplay fitted. My iphone 11 connects to the carplay, with the pop up display showing all the Apps. I can select different Apps using the idrive, google maps displays as does album artwork and my phone contacts.
Only problem is that on playing an album there is no sound. When I try to make a call, it doesn't use the car mic/speakers.
The carplay unit is hooked into the AUX jack. Looking at the multimedia sub menu AUX is selected and the volume is turned up on the AUX sub menu.
Am I missing anything obvious here? Everything seems to be connected and talking to one another, but clearly something is out.
Ta.
Carplay Conundrum
Carplay Conundrum
So to determine if the AUX socket actually works plug something else into the socket and play some music, if you can hear it then it's something to do with the MMI box, if not then you've got an issue with the AUX socket.... time to investigate further physically.
If it does play a sound then it'll be something wrong with the MMI, this could be as simple as the AUX lead may not be plugged into the MMI box loom (may have come out as it's a flying lead socket on the loom). There is also a volume out setting within the mmi box settings page.
The fact that you can adjust the AUX input on the iDrive menu screen means that it has recognised that something is plugged into it (it's not selectable if there is nothing plugged in).
So hopefully a little to go on there
Dave
2011, 23i, Grey with Red leather.
Carplay Conundrum
I occasionally get no sound on mine - everything looks like it is working, but silence.
I've found that flipping back to the standard BMW radio shows that it has actually been muted! just unmuting, then flipping back to carplay & all is fixed.
It's a minor annoyance that crops up maybe one trip in 10, and now I know the fix, it's a 10 second problem.
- B21
Carplay Conundrum
I have the same issue..I think that's caused by some glitch in the MOST bus switching logic...matsmith749 wrote: ↑Fri Aug 11, 2023 11:19 am I occasionally get no sound on mine - everything looks like it is working, but silence.
I think the OP had something slighltly more primitive happening in his 3.5mm audio jack version..IMHO
A very modified Atacama Yellow 35is Previously a slightly less modified Atacama Yellow 20i MSport
Carplay Conundrum
Gents, there is a known issue with Android Auto and Apple Music where sometimes on changing a song it will carry on playing but there is no sound. The remedy is to press the iDrive controller, which pauses the music, then press it again to restart it.
I wasn't aware this was an issue with CarPlay as well. I do know that it's got nothing to do with specific phones or any specific make of MMI box as I've had it on both of my boxes and all three phones that I've had in that time.
Dave
- B21
Carplay Conundrum
I’ve seen that type of bug, albeit with YouTube music..I get a slightly different one ..if I use a native sound source played direct on the iDrive if I then go to try and play audio on the MMI it ‘plays’ but no sound…AnubisZed wrote: ↑Fri Aug 11, 2023 3:19 pm Gents, there is a known issue with Android Auto and Apple Music where sometimes on changing a song it will carry on playing but there is no sound. The remedy is to press the iDrive controller, which pauses the music, then press it again to restart it.
I usually hold the idrive controller down for 10 seconds…when it reboots the sound is there…
- DJ23
Carplay Conundrum
Thanks everyone for the comments. Been away all weekend ( unfortunately not in my Z4 )
So the aux jack seems to work - I have an old adaptor I used in a 4 series I had a few years ago that worked when I swapped them out so thats good - and is now in the car as a standby.
I fiddled about with the setup menu on car play, disconnected and reconnected my phone and it now seems to play music which is great. Google maps seems to work as well, but not the phone - will appear to make outgoing calls but there is no ring tone/sound or connection. I wonder if its to do with my Siri settings (which isn't set up). I'll have a play with that later.
Also respect AnubisZed - watched you do a MMI fit on your BMW Z4 mods channel. Very impressive.
Carplay Conundrum
Glad you like my channel, it's there to help people do "stuff", so it's good that you've found it useful
As for your phone, check your bluetooth settings on the phone, check that it is set for "Calls & Media". If it's only set for "Media" then that'll be why, just change it on the calls as well. If it is set for both already, then you'll have to look further into the box settings menu.
Dave
