BMW howling sound from the rear end.
Hello,
[E85_200_3.0_6_speed_manual]
I have this weird noise https://www.youtube.com/watch?v=_GPyuxuyJRw around 20-30km/h (12-18mph) during the acceleration. Now I changed the differential, but the issue is still the same.
I have poli bushings, but the noise was noticeable with the originals too.
Maybe every diff has this sound? Or coming from the different area? Any idea?
first thought for rotational noises is usually a wheel bearing...
Yes, that occurred to me too, but none of the YouTube videos have such a noise, they were more like growls.
- MikeyH
Something to do with the prop shaft ? Universal joint, is there a clunking noise when you lift of the accelerator?
- enuff_zed
If it's at just those speeds is it resonance? Something vibrating at just that frequency?
I had a wah wah wah wah noise from the rear, turned out to be the rear tyre's had gone out of shape.
Nice and quiet now
Nice and quiet now
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Hey, no clunking noise, but the howling only come during the acceleration, also changed the tires 2 weaks ago. Yes maybe resonation, but i cannot find any loosen suffs, and i think it should resonate both during accel-deccel.
- MikeyH
Do you have split rims, are the screws tight? Someone else on here had an odd noise and the screws were loose.
There are a few on here with a screw loose, mate!
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- MikeyH
I thought they had been banned oopps
2011 z4 30I
I'm getting a slight humming sound from the rear differential area. changes intensity with the rpm change? I've changed the fluid but noise still there? 105k miles any one have any ideas?
Check your rear tyre's, mine had gone out of shape, I thought my diff was going. New tyre's and nice and quiet now.ml1nov1980 wrote: ↑Wed Jul 19, 2023 9:05 pm 2011 z4 30I
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
- GreyZed
Don't under estimate how much noise tyres can make. I had a set of cheap tyres on an E85 I bought and I stopped 3 times on the way home that day they made so much noise - thought a wheel bearing was disintegrating! Put new tyres on a week later and silence.
3.0 auto, sterling grey, hardtop, prfessional nav, dsp, digital tv, bluetooth, cruise, xenons, mfsw, cupholders, auto lights, auto wipers, folding mirrors, memory seats, wind deflector, pdc, 108s, LED sides/fogs, stubby, intravee, need a quad exhaust!
firebobby, from ml1nov1980. When you were getting noise from your tires did the noise go up and down with the rpm's?? The noise I have will increase slightly in sound when I accelerate and then stop when I let off the gas?? So It must only make the sound when it is under load or torque? I'm thinking tires would be a constant hum sound and not change with the rpm?? Your thoughts!! I do have the run flat tires on the car, very noisy, and rough riding but still in good shape! Thanks for the response! Mike
I'm not sure, but think it did. I found run flats, terrible for handling on my car.ml1nov1980 wrote: ↑Thu Jul 20, 2023 2:22 am firebobby, from ml1nov1980. When you were getting noise from your tires did the noise go up and down with the rpm's?? The noise I have will increase slightly in sound when I accelerate and then stop when I let off the gas?? So It must only make the sound when it is under load or torque? I'm thinking tires would be a constant hum sound and not change with the rpm?? Your thoughts!! I do have the run flat tires on the car, very noisy, and rough riding but still in good shape! Thanks for the response! Mike
How old are they, try jacking the rear up and running it in gear, see if the tyre's are out of shape.
Like I said, my tyre's were the cause of the noise, and it sounded like the diff/bearing noise.
Hope that helps
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
