So I’m rebuilding the vanos on my s54 and have read about resetting vanos adaptations after rebuild, this is preventative maintenance rather than being broken but the timing on the exhaust camshaft was out a few degrees.
Does anyone on here have an obd scanner I can use to reset my vanos adaptations in the surrey area?
I’ve tried to download inpa, ista, dis and all the others and none will let me perform any vanos tests.
Any help is much appreciated.
Andy
Vanos rebuild, does anyone have an obd scanner in surrey?
2007 Z4M Coupe
Yes the system using INPA, and a pressure test, is all ok, leave it alone
I've rebuilt and fitted many s54 vanos units over the years and not had to reset any adaptations. I'd make sure your using the genuine BMW timing tools and double check the timing by turning over, well, twice!. Happy to advise, just drop me a pm.
2008 Z4MR Ruby Black, Sepang Hell, Carbon Weave
2006 Z4 3.0si Montego Blue, Imola/Black individual
NCS/ISTA diagnostics & coding in Midlands - pm me
