Dealing with very hard water?
- pvr
I am still waiting to dry up here so I can cut the grass. Can’t remember the last dry day
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
- TOMGREEN413
Glad I live in Wales....your welcome to some of ours..
White e89 Red leather interior (But that's the wife's and don't I know it :/ )
Montego Blue Coupe manual si sport (Faster than the above....much faster
Interesting...are you using the 7 litre version and how long before replacing the granules?IRD wrote: ↑Fri Apr 28, 2023 1:35 pm A company called Raceglaze makes water filters of varying sizes which connect to you hosepipe and the rinse the car. The filters are filled with resin which you replace every two years.
When youhave done the usual washing etc give a final rinse with water passing through the filter. There is no need to wipe dry. Just leave to air dry and the car will be spot free. Even windows dry clear. Not cheap but works really well.
I have just received my replacement refill and will doing it this week.
All the info is on their website.
Hope this helps.
2023 BMW Z4 G29 sDrive 20i M sport in Thundernight
2024 BMW S1000 XR TE, black storm metallic
Online
I bought the bigger 14litre version and mounted it on an old sack trolley so it stays upright and is easy to move. The granules have lasted just over 2 years. I have only recently replaced them. Most weeks I have used it to rinse two cars after washing them. Not cheap but works really well. I am glad I bought it.millview22 wrote: ↑Sat Jun 03, 2023 5:11 pmInteresting...are you using the 7 litre version and how long before replacing the granules?IRD wrote: ↑Fri Apr 28, 2023 1:35 pm A company called Raceglaze makes water filters of varying sizes which connect to you hosepipe and the rinse the car. The filters are filled with resin which you replace every two years.
Hope this helps.
- IMG_0277.jpeg (238.03 KiB) Viewed 948 times
- Nanu
Try using a clay mitt rather than a bar, much easier.
G29 M30i M Sport San Francisco Red
Previous
E89 35is Valencia Orange
E89 28i Crimson
E89 25i White
Previous
E89 28i Crimson
E89 25i White
The lengths (and expense) people go to are truly astonishing IMHO.
Using a sledgehammer to crack a walnut springs to mind!
I've lived in extremely hard water areas all my life (and current location is very very hard).
As long as you dry a car with a microfibre towel before the water evaporates there is no problem with limescale IME, especially if it is waxed every once in a while.
As for removing 'baked on' scale, I would use a very diluted limescale remover, then rinse and keep repeating it until the residue has been dissolved.
T-cut will shift it aswell, if it's really cooked on!
F31 320i. Good car.
E89 20i Now fully dried
Mazda3 sold
F31 320i. Good car.
Mazda3 sold
- TOMGREEN413
I lived in a hard water area when growing up and have got denchers to prove it.....its a serious business
- Boyo
I use a Raceglaze water filter aswell. Great piece of kit and totally eliminates water spots.IRD wrote: ↑Sun Jun 04, 2023 7:40 pmI bought the bigger 14litre version and mounted it on an old sack trolley so it stays upright and is easy to move. The granules have lasted just over 2 years. I have only recently replaced them. Most weeks I have used it to rinse two cars after washing them. Not cheap but works really well. I am glad I bought it.millview22 wrote: ↑Sat Jun 03, 2023 5:11 pmInteresting...are you using the 7 litre version and how long before replacing the granules?IRD wrote: ↑Fri Apr 28, 2023 1:35 pm A company called Raceglaze makes water filters of varying sizes which connect to you hosepipe and the rinse the car. The filters are filled with resin which you replace every two years.
Hope this helps.
Current:
718 Cayman GTS 4.0 (PDK)
Previous:
G29 M40i - Thundernight
718 Cayman GTS 4.0 (Manual)
987 Boxster 2.7
E89 2.0i M Sport (Auto)
E89 2.0i M Sport (Manual)
718 Cayman GTS 2.5
E89 35is
E85 M Roadster
Previous:
987 Boxster 2.7
718 Cayman GTS 2.5
E89 35is
E85 M Roadster
- pvr
I use two in serial. That way, you are not throwing the product away until it is really buggered. The second vessel takes the worst out and then the other one has less work to do
Current:
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
Online
Really good idea. Never thought of doing that.
- PaulN
My z4 got watered one time while it was parked at my ex InLaws and the gardener watered the lawns…
It was really bad and the paint was perfect, I managed to get 95% off with Chemical Guys Speed Wipe Quick Detailer and then Zanio Z6 Quick Detailer….
For hard water as others have said I use a RI resin Vessel…. For the Z4 I even use that water to wash it too…. If you can finish rinse with water from the hot tap that would reduce a lot… you get more spotting from the direct cold main pressure….
Everything Happens for a Reason!
14 TT Black Edition
07 Z4 2.0 SE Jet Black
06 Freelander Sport Java Black
14 TT Black Edition
I use filtered rain water to wash my cars - 3 water butts in series with filters then run the pressure washer off the last in line - works a treat and no arguments when a hose pipe ban comes into effect.
