Typical!
- LawrenceW
Typical!
Lol - anyway, back home all cleaned, happy days
- E17DD28A-F5EA-47BA-B16A-D852BC0A9527.jpeg (169.69 KiB) Viewed 692 times
- 824A78FC-2DB9-4E47-9142-94A3FAD5087E.jpeg (141.53 KiB) Viewed 692 times
Typical!
Took mine out for it's 'Shakedown', for want of a better word, test run today after all the mods, brakes were absolutely shite as expected until I'd done the heat cycles, sooooo much better now, again as expected, some adjustments needed to the bump, rebound, and ride height, but already feels night and day to stock.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Typical!
I'm just fitting new discs and pads on the rear, and whilst there I am putting new handbrake shoes and fittings.
Having it all open and visible underneath, I can see the majority of bolts are rusty, and the alloy wishbone and diff casing are very crusty, with a white powdery residue. No doubt this is because it has lived outside between 2008 and 2019. At only 38,000 miles its letting the car down. the clips that hold the rubber gaiters in the drive shafts are particulalry unpleasant - real shame these weren't stainless
Would love to have the time to do as you guys have done, my problem is motivation, and then where do you stop cleaning, and stripping down and sending away to be coated/painted.
Are you using any special cleaning products, or is it just elbow grease?
2008 Z4MR Silver Grey
2017 Audi A6 Avant Quattro 3.0 BiTdi
2003 Clio 172 Cup
2003 Clio 172 Cup
Typical!
My efforts today, I used a mild phosphoric acid to wipe off the general rust staining, and will apply a rust convertor that turns it black before reassembly. Should look good once all the new hardware arrives, then will disappear once the new discs are fitted.
before after
before after
2003 Clio 172 Cup
2003 Clio 172 Cup
Typical!
Personally I think you've made good progress Justino, you can only do so much with axle stands and whatever your motivation. Also doing something to more detail involves the car being off the road for significant lengths of time. My only issue with so called rust treatments is ultimately they're covering rust, not getting rid of it, so longevity has to come into the equation at some point, but as i said from what you've said and done so far it's all good.Justino wrote: ↑Sat Apr 08, 2023 9:42 pm My efforts today, I used a mild phosphoric acid to wipe off the general rust staining, and will apply a rust convertor that turns it black before reassembly. Should look good once all the new hardware arrives, then will disappear once the new discs are fitted.
MR2 MK 2
E89 35is
G29
MR2 MK 2
E89 35is
G29
Typical!
I should really have done all this over the winter, but a cold barn doesn't help the motivation either.
I have a scissor car lift on my wish list of things to get, that would help no end with access underneath - or do I just drop it down at Reddish and let them do their magic.
Maybe wishful thinking, but just swapping out the rusty bolts on the underside would lift it no end, along with the drive shaft/diff gaiter clips, get the alloy wishbones sent to TS Engineering who do a coating to stop alloy corrosion, along with the any other brackets, track control arms, anti roll bar etc etc.
Ideally the disc backing plates would want painting, but I dont fancy taking the hub off and distrubing the wheel bearing etc, but it would need to come off to get the stub axle painted.
After the brakes I need to refit the airbox having fitted a new starter motor after it failed in Turin! I was going to get a Karbonius but an impending divorce, have put that extravagance on hold for now until I know where I am. A job for the winter I think.
2003 Clio 172 Cup
2003 Clio 172 Cup
- LawrenceW
Typical!
Just elbow grease for me plus the usual wire wheel on a drill, a dremel for the little rust scabs in the floor pan etc (I may be motivated to do a decent job but my skill level runs out of road pretty quickly)Justino wrote: ↑Sat Apr 08, 2023 9:25 pm I'm just fitting new discs and pads on the rear, and whilst there I am putting new handbrake shoes and fittings.
Looking at the before and after rear brake splash guards, that’s pretty impressive, was it off the shelf stuff?
Btw I wasn’t brave enough to do a proper job on the back of the car I.e dropping and refurbing the rear subframe etc. Also good point about the rusty clips around the drive shaft gaiters, as I think the clips used around the gaiters on the steering rack are stainless.
- inkey$
Typical!
This is the kind of car you dream of finding for sale. Great work, OP. Beautiful
Previously: Z3R 2.8 • E46 330i • Z4R 3.0 • Z4///MC • E90 335i • Z4///MR • Z3///MC 'Breadvan' • Z3R 2.8 • E30 325i R • Z4C • Z4R 3.0
Typical!
Motivated by all your efforts I’ve had an afternoon on the rear whilst the brakes are off and I’m waiting on parts to arrive to start reassembly.
The phosphoric really gets the old brake dust off the calliper and hanger. I will get some black calliper paint to touch up the various chips in the paint before a full refurb at some stage.
It’s also a good stainless cleaner. I will do these properly when I remove them to fit the new exhaust tips.
What is nasty is all the fittings around the diff. Ignoring for now.
You can see the general surface corrosion on this pic of the ABS sensor.
What I would like is all the running gear removed, blasted, coated, all consumables replaced, use stainless bolts etc. wonder what the cost at Reddish would be.
The cleaner has a wetting agent which has left a residue. I will rinse off with hot water in a pump sprayer.
- 2169C0F9-6F03-48F6-8614-7BCF52CC7F11.jpeg (177.84 KiB) Viewed 509 times
2003 Clio 172 Cup
2003 Clio 172 Cup
- Beedub
Typical!
lovely john, heads up.... the rear spring adjustable top perch has its own rubber feet, the oem TOP rubber is meant to be removed as per the instructions of the suspension units.... The lower oem rubber that sits in the arm/ bottom of the spring is reused on the new spring.
- LawrenceW
Typical!
Great work Justino. Ref Redish supporting with underside refurb, I don’t know what their hourly rate is but I guess with dismantling, blasting, painting/coating, reassembly it wouldn’t be cheap but as no doubt you’ve seen on their you tube vid’s their work can be impeccable (owners budget permitting). I know Wassup on this forum offers a great deal of blasting, powder coating and refitting of all genuine bushes to the rear subframe for under £400 (apologies if I’ve misquoted Wassup) which to me is amazing value.
Either way your ZM staring to look really good
- pvr
Typical!
If he could do my subframe I would certainly do that
Current:
911-50 Black - unique spec
X5M - 575 hp of fun in a V8
Abarth 595 Comp.
Z4 3.0si Black Sapphire
VW ID.3
Previous:
Z4 3.0 Toledo
Abarth 595 Comp.
VW ID.3
Previous:
Z4 3.0 Toledo
